Dremel Trio
Offline Andreas
Dremel Trio
on: August 28, 2010, 07:19:23 PM
Dremel has apparently come out with a new tool, the Trio:
http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=Dremel+Trio
"The Dremel Trio allows users to cut, sand and rout using one multi-purpose tool. Cut multiple materials including wood, plastic, drywall, sheet metal, wall tile and more without switching tools. The tool’s unique, 360-degree cutting technology and plunge-cut ability allows users to make quick and controlled cuts, while its unique, 90-degree pivoting handle facilitates added control, comfort and accuracy.
    * The multi-purpose cutting bit included with the Dremel Trio lets you cut a variety of materials using only one bit
    * The pivoting handle on the Dremel Trio can be positioned straight-up or at a 90-degree angle for superior tool control and maximum comfort
    * Start your cut wherever you want because Dremel Trio cutting bits let you make quick and easy plunge cuts anywhere in the workpiece"
 :gimme: :gimme: :gimme: :gimme: :gimme: :gimme:
Re: Dremel Trio
Reply #1 on: August 28, 2010, 08:32:09 PM
Cool but not much different from their router attachment is it.  At least for lightweight stuff.  I'm probably missing something :)
Offline Andreas
Re: Dremel Trio
Reply #2 on: August 28, 2010, 08:33:31 PM
I have the router attachement and you can't cut that fast with it. . But you're right, very similar
Re: Dremel Trio
Reply #3 on: August 28, 2010, 08:40:47 PM
I think there maybe some CGI trickery in that video ;)
I want to know when they are going to bring a CNC attachment :P
I jest but it would be very cool  8)
Offline Andreas
Re: Dremel Trio
Reply #4 on: August 28, 2010, 08:44:33 PM
Yeah of course it's CGI, but if they are marketing it as a jigsaw type thing it has to be able to cut faster than what the router attachement setup can do.
CNC would be epic
Re: Dremel Trio
Reply #5 on: August 29, 2010, 02:48:07 PM
I played with it at Home Depot a few weeks ago.  There's really not much you can do with it that you can't do with a standard Dremel, but this one does it faster and probably better.  It's more purpose oriented, which almost always makes a difference.  I found myself wanting one!
Offline Andreas
Re: Dremel Trio
Reply #6 on: August 29, 2010, 03:09:12 PM
Anything Dremel rocks. I bought a cheap fake dremel a few days ago as I thought I could get away with using that here at my digs, but Iæm having my real Dremel shipped here from home because the fake one is a joke   :rofl:
