Superb job, and very useful too So you didn't need to even drill a tiny pilot hole for the screws?
Something I was happy about was the fact that the metal screws self tapped themselves into the alox scales. I was concerned I would need to manually tap the holes after I drilled them, but my tap kit doesn't have a tap this small. I tested one screw and found that it actually tapped the hole very well. I presume the steel is harder than the aluminum.
Quote from: nuphoria on September 27, 2010, 04:01:03 PMSuperb job, and very useful too So you didn't need to even drill a tiny pilot hole for the screws?He did drill a hole, but he didn't have to tap them...Quote from: Aloxfan on September 27, 2010, 06:11:03 AMSomething I was happy about was the fact that the metal screws self tapped themselves into the alox scales. I was concerned I would need to manually tap the holes after I drilled them, but my tap kit doesn't have a tap this small. I tested one screw and found that it actually tapped the hole very well. I presume the steel is harder than the aluminum.
Great stuff, can you let us know what screws and clip you used so we can try it as well?Please do tell.Robert.
