it seems mine is the "X" rather.
Scissors on ST Spirit are, if not the most criticised tool on it, than right after „butter“ knife. Here are some thaughts about them. After some inspection and comparitions STS scissor apear to be sturdier, somewhat thicker and with strong ends. Well my impression is that, like everything on STS, they are made for serious business. This MT is constructed to be on the „front line“ doing some serious stuff, along with that scissors on this tool aren’t made for just paper cutting, or some thread, or something like that, they can do this job as well as any other. What I think is that this scissors are made for somewhat harder cutting. Now I come to it’s not so wide oppening and slight shorter cutting edge. As I see this is not a problem, it’s just constructional solution which should prevent cutting oversized things in order to keep scissors on the „safe side“ and prevent applying to much pressure which could end with serious damage. If I have to choose between a bit wider opening and bit longer cutting edge against sturdier design, and safety in cutting somewhat stiffer and harder things, I will go for the other one. As I have stated, those are just mine initial thaughts. I’m not MT expert, not even serious user, I’m just a guy with some thaugts about this, and comment’s are more than welcome!!
