First, I will start this as I am a police officer. I use multitools everyday and I prefer the one handed opening over the nail nick on the swisstool or the 30 second process on my powerlock! But today I tried my Swisstool and I am not impressed. I was in my police car driving on a main road and I saw a dog trapped under a fence. So today I brought my new swisstool rs to try it out. I tried to use the swisstool wirecutters to cut the fence and it was unable to cut it. So I always keep a leatherman surge in my duty bag so I ran to the car and used the stranded wire cutters to cut the fence with ease.
It would have had to have been some serious fencing, a friend of mine and I faced off a long time ago with a race between a ST and a Powerlock to see who could cut through the steel the quickest. The diameter I am not sure exactly, but it was chain link fence easily if not thicker. The Powerlock did it with ease but the swisstool did not fail either, he had to squeeze a heck of alot more but the ST showed no signs of damage.David
Thanks, now to mention it the wirecutters on my swisstool are not very impressive. The struggle cutting the thick coat hangers. Possibly my tool is damaged. But that could also be because the swisstool wirecutters dont cut clean they bend and then cut
I done a video a while back showing a swisstool cutting a coat hanger to bits , its in the multi media section on here . As for using the file to cut the fence ? you cant as the RS hasnt got one Dunc
I have not used leatherman surge before. I once tried to cut a wood screw using Charge Ti. It did cut the screw tip, but also damaged its piler tooth, the alignment is change and even hard to close the plier. I tried Swisstool RS, it cut the wood screw with ease, even the diameter of screw is bigger.
Quote from: anbqanbq on October 16, 2007, 10:07:35 PMI have not used leatherman surge before. I once tried to cut a wood screw using Charge Ti. It did cut the screw tip, but also damaged its piler tooth, the alignment is change and even hard to close the plier. I tried Swisstool RS, it cut the wood screw with ease, even the diameter of screw is bigger.That's pretty impressive cutting performance mate Was there any damage to the wire cutter at all
One more word, I really like Ti's big knife with the function of one-hand-open. Hope Swisstool could adopt this advantage later.
