Cap crimper plier head and c4 Spike are the only differences that I can see that distinguish the EOD from the regular MUT.
The Spike on the EOD is larger, and thus the base insert is shaped to fit it. You could put the pin instead of the spike with no problems on the EOD model, but you wouldn't be able to fit the spike on the non EOD model as the base insert won't allow it.
