A nice way to spend half the day.
Chako · 19 · 1847
on: January 03, 2011, 12:07:39 AM
I promised to gift a very special person a leather belt. Now I hadn’t done a leather belt in a couple of years, and with the last leather piece done not that long ago, I figured it would be a good thing to get back into the swing of things in regards to leather crafting. Thankfully, much like riding a bicycle, you just never forget the basics. Still a little rusty in some of my techniques, and I know that comes from lack of practice…but the foundations are still there. Whew!
Anyways, my idea behind this project, was to highlight some of the owner’s qualities. A love of astronomy is shown in the simple but time consuming star background. A love of geology is evinced in the crystal centers. Likewise, each of the 5 evenly spaced crystal backdrops is different, but each signifies something about the person.
Enough babbling and onto the photos. I am going to attempt to show you the steps I took to make the belt.
1.   I used a belt blank for this project. These come with the two snaps already pre-fitted and the belt comes a standard length that is trimmed to your needs. The first step is to use a specialized tool that turns a swivel knife into a line cutter. Simply run the blade along the belt being sure to only press lightly so as to not cut more than half way through the belt.
2.   I next use a belt tip cutter to shape the squared off tip. This will allow better fitting of the belt tip protector later on. At the same time, I use a #2 Edger tool to round the front and back side edges. I run this tool along each edge corner. This makes the belt a lot more comfortable to wear…and also aids in the finish that will come later.
3.   Now comes the long stamping part. Here you can see the small star stamp and my stamping mallet. You have to wet the leather first which makes the leather easier to imprint.
4.   After completing the stamping part, I then cut the holes in the belt for the belt buckle. I always use a special oval punch. Round holes don’t allow the buckle bar to work properly. The needle is there to clean out the leather punch after each strike.
5.   I then re-wet the leather and used this stamp to push the leather down on the inside, producing a nice edge effect to the belt. At the same time, I measured the belt and punched 5 holes for the crystal rivets and shields using a small round punch.
6.   This next step is very important. I use natural Neatsfoot oil and apply a liberal amount to both sides of the belt. This oil impregnates the leather and reconditions the belt. After this application, you have to work it in by bending the belt a few times etc. I let this soak in and dry before going to the next step. The oil does darken the leather FYI.
7.   Next I use a specialized slicker to finish the edges. The slicker is nothing more than a nylon round pulley. I sometimes attach the slicker to a rotary tool, and hence the metal shaft, but I usually use it by hand most of the times. To use the slicker, you have to wet the edges with water and then rub the slicker over the edges repeatedly. There are different techniques for this, but I prefer simple water. The oil also aids in giving you a nice professional edge to your belt…hence why I do this after the oil application.
8.   Now comes the dying of the belt. I used a medium brown dye. I rub some dye on the belt and then quickly rub it away with a wet sponge. This way, it dyes the crevices but leaves the foreground lightly dyed.  I didn’t take any photos because I had to wear gloves. This step is always messy.
9.   Next, fit the belt tip protector and hardware for a dry fit. Trim where needed and then using a metal stylus, I gently tap my holes into the screw holes and then install the belt tip protector.
10.   With the hardware in place, I then finish the belt with an acrylic clear coat sealer. It goes on white but dries clear after a few minutes. This seals all the dyes so that it won’t come off on the wearer, and also protects the piece from moisture. Once dry, I take a dry cotton rag and buff the belt.
Well that is it. The belt took me about 5 hours to make. Here is the finished product.
I hope you enjoyed this quick rundown on my techniques in making a leather belt.
« Last Edit: January 03, 2011, 12:09:57 AM by Chako »
us Offline rioredgt
Re: A nice way to spend half the day.
Reply #1 on: January 03, 2011, 12:49:35 AM
Beautifull!
Robert
um Offline Mr. Whippy
Reply #2 on: January 03, 2011, 01:55:01 AM
Wow!  :o
Chako that is beautiful!  :tu:
Reply #3 on: January 03, 2011, 02:15:42 AM
very nice work  :tu:
us Offline Crouton
  • "Live long and ..useful."
Reply #4 on: January 03, 2011, 02:34:11 AM
Nice work Chako.
Reply #5 on: January 03, 2011, 02:42:01 AM
Thanks.  :salute:
us Offline thebullfrog
Reply #6 on: January 03, 2011, 04:14:43 AM
Very, very nice work. Actually looks like a damn fun hobby.
us Offline Smitty44
Reply #7 on: January 03, 2011, 06:32:13 AM
You are a man of many talents,great job,and looks fabulous. :cheers:& :salute:
ca Offline Sean
Reply #8 on: January 03, 2011, 08:25:50 AM
Damn, I'm amazed!  :tu:
il Offline Threeme2189
Reply #9 on: January 03, 2011, 11:37:26 AM
Amazing work!!!
gb Offline sousterre1
Reply #10 on: January 03, 2011, 01:02:29 PM
That's real talent, it looks amazing.
All mushrooms are edible, some only once.
nl Online Reinier
Reply #11 on: January 03, 2011, 01:42:42 PM
The end result looks beautiful! Very professional :)
Very nice to see the different techniques involved. Thanks for posting this! :tu:
Reply #12 on: January 03, 2011, 02:41:21 PM
Thanks everyone.
I thought this one wouldn't take so long as all I did was stamp it with a small star. I was going for texture and symbolism. That took a lot of time, as I had to hit each star twice to get it nice and deep even with the leather being damp and all. But this took as long as it did for the next two belts I am going to show you…
Here are two examples of belts I made a few years ago with a somewhat common theme. The first for a local train nut who happens to be the father of a dear friend. He has a railroad system in his back yard that you can ride on that he calls the O.G.B Rail. I used his carnival ride sized train as a model. The other was for a guy who worked on the trains at the local steel mill. Each of the trains on his belt where actual trains used in the train yard that he worked on, in, or around. The trains took a lot of time, as I only had 1 1/2" to work with...and I wanted lots of details. I was working from photos found online.
Now I show these because they required carving the leather and then stamping it. Carving refers to the use of a swivel knife to cut the leather half way through, and then using a beveler (what I used to make that raised edge in the newer belt) and other stamps to give the leather that raised 3D look. A different technique but the results are nice.
nl Online Reinier
Reply #13 on: January 03, 2011, 02:49:09 PM
Now THAT is awesome! Amazing how much detail you got into those designs. Really nice work!
cs Offline Vladimir
Reply #14 on: January 03, 2011, 03:06:36 PM
Wow, amazing work!
it Offline sardauker
  • Just arrived
Reply #15 on: January 03, 2011, 03:36:40 PM
wow :D  :drool:
cs Offline edcgear
Reply #16 on: January 03, 2011, 05:14:16 PM
 :drool: :drool: :tu: :tu:
ΜΟΛΩΝ ΛΑΒΕ
Reply #17 on: January 03, 2011, 07:36:16 PM
You're a talented guy Dan..  :tu:
Reply #18 on: January 04, 2011, 07:14:07 PM
now that is sweet! nice work again!
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
