Ceramic folders
jzmtl · 14 · 2038
ca Offline jzmtl
Ceramic folders
on: January 12, 2011, 04:31:08 AM
So I keep hearing how they suck, from people who probably don't have one. I took the plunge and bought one, and going to see how it works out in real life.
Fit and finish is good, the single liner isn't entirely flush with CF scale on butt of handle, but I suppose since liner is TiNi coated it can't be sanded after assembly to make it so. Liner lock feels solid, action is very smooth, and the whole knife is really light.
Out of box it's not particularly sharp, doesn't shave, but cuts stuff fine. When I work up enough courage I'll put it to my belt sander and see if I can make it better.
us Offline Crouton
  • "Live long and ..useful."
Re: Ceramic folders
Reply #1 on: January 12, 2011, 04:48:30 AM
What make and model is that?  It's a handsome piece.
ca Offline Sean
Re: Ceramic folders
Reply #2 on: January 12, 2011, 06:46:06 AM
+1 give us some details.  :)
us Offline Sazabi
Re: Ceramic folders
Reply #3 on: January 12, 2011, 02:20:33 PM
The only ceramic folders I have are the two variations of the Boker ceramic gent knives; they're neat, but not for carrying. :/
ca Offline jzmtl
Re: Ceramic folders
Reply #4 on: January 12, 2011, 04:04:23 PM
It's from ceramicknife.org, he's in Ontario, but the knives are contracted in China I believe.
Funny thing is the blade and clip looks identical to boker plus anti-MC, probably from the same maker.
Boker tree brand ceramics are pretty darn small, not sure how useful they are. This has 3 1/4" blade so actually pretty nice sized for EDC.
Offline Styerman
Re: Ceramic folders
Reply #5 on: January 12, 2011, 04:21:07 PM
Don't pry , don't drop , it will hold a lethargic edge forever . I had a couple of paring knives and a pair of scissors - not for me thank you .
Chris
ca Online Grant Lamontagne
Re: Ceramic folders
Reply #6 on: January 12, 2011, 04:27:04 PM
I wouldn't put it on a belt sander, but that's just me.  I'd be paranoid that the vibrations or even just a small amount of uneven grit would make a mess of the blade.
I haven't had any folders, but I have had a few ceramic kitchen blades and I always used a small diamond dog bone to keep them sharp.
ca Offline jzmtl
Re: Ceramic folders
Reply #7 on: January 12, 2011, 04:45:40 PM
I'll test the sander on the spine first and see if it works, if like you said there's too much vibration I'll have to do it manually.
They actually seem pretty tough compare to the typical perception of ceramics, there's a guy on youtube dropping his kyocera on hard kitchen tile repeately and it didn't break.
ca Offline jzmtl
Re: Ceramic folders
Reply #8 on: January 23, 2011, 06:23:10 PM
My adventure with this ceramic knife has come to an abrupt end. Liner lock and ceramic blade just doesn't mix, since one is way harder than the other, the lock bar is quickly wore away and reached end of ramp, and I fear it will simply slide pass the tang one day with enough wear.
Not completely given up I got a Boker anti-mc instead, which has almost the same blade, but Ti frame lock instead. Which should be better performing, since it's much thicker and will be stopped by the other handle instead of slide pass tang (the scale is thicker than the blade, and lock bar is much more springy than the liner lock).
ca Offline jekostas
Re: Ceramic folders
Reply #9 on: January 23, 2011, 08:15:00 PM
Okay, I've heard of crappy, unsharpenable edges, I've heard of people dropping them, I've broken one due to twisting when cutting but the liner wearing away in less than two weeks?  Yeah, that's new to me.
ca Offline jzmtl
Re: Ceramic folders
Reply #10 on: January 23, 2011, 09:07:59 PM
Could be just the one I got too, I'll see how the boker holds up.
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
Re: Ceramic folders
Reply #11 on: January 23, 2011, 10:25:28 PM
I have both models of ceramic, they perform well for occasional use but they definatly don't fit the bill for EDC use. On normal use my blades can get a rolled edge, ding or chip depending on the hard use I give it. I don
t recommend ceramic for most folks because they are even harder to sharpen and I have not crossed that bridge yet. I'll stick with regular steel any day of the week  :tu:
ca Offline jzmtl
Re: Ceramic folders
Reply #12 on: January 24, 2011, 04:02:52 AM
That's what I'm trying to find out for myself, though I don't do anything that would roll or chip my knife. So far I like it for cutting food, because I don't have to wash it right away (or at all) after cutting acidic or salty food.
Sharpness isn't good though, neither can shave, but the very thin edge (thinner than many steel knives) does cut okay.
The boker is now in my EDC rotation and I'll see how it holds up.
Interesting/funny tidbit, you can touch up/steel regular knives on the spine/side of ceramic knife.
Okay now I know why it doesn't shave, the edge angle must've been over 50°! Looks like it'll meet the sander sooner than I had planned...
« Last Edit: January 24, 2011, 06:55:51 AM by jzmtl »
ca Offline jzmtl
Re: Ceramic folders
Reply #13 on: February 09, 2011, 01:23:51 AM
Hard lesson learned, ceramic blade won't hold 30° edge.  ::) Well not hold, just can't put a 30° edge on it to begin with.
