Ripping down corregated cardboard, rather than using the knife blade and risk running into staples. Only done it a few times, then switched to a slimmer SAK for EDC
with the SAK...use your imagination...you'll find 100's of new uses.
Not quite convinced that it'd do much for my moustache but the rubber band shooter is inspired.
Quote from: Gareth on April 11, 2011, 07:23:30 PMNot quite convinced that it'd do much for my moustache but the rubber band shooter is inspired. I'd like to see someone comb their moustache with a SAK. =)
20: Drawing compass (is that the right term ). Insert pencil into tip (the hook disgorger), rotate fish scaler around its pivot. Repeat until circle = finished This is 100% hypothetical, haven't actually tried this
Drawing compass... nope. I tried it, doesn't really work
Quote from: Reinier on April 13, 2011, 10:01:24 PMDrawing compass... nope. I tried it, doesn't really work What if you do it the other way round? Insert a pencil/pen at the tip, then insert another pencil/pen in one of the teeth, and rotate around the tip pen (i.e., the tip is the compass pivot).
Quote from: Nikos on April 14, 2011, 10:03:14 AMQuote from: Reinier on April 13, 2011, 10:01:24 PMDrawing compass... nope. I tried it, doesn't really work What if you do it the other way round? Insert a pencil/pen at the tip, then insert another pencil/pen in one of the teeth, and rotate around the tip pen (i.e., the tip is the compass pivot). I guess you have to use your third hand to hold the SAK still huh?
