If you look at my photos the bottom one has 2 holes in the adapator. Is yours like that or the one on the blue background? Would either one work with the Mini Tool? Most sites only say they are for the PST and Wave and not Mini Tool?
I have the Kick and Supertool 300. I have the adapter that slips over the Phillips screw bit. It works, but is a little sloppy. Has anyone used the Universal tool/bit Adapter above with either/or The Supertool 300 and or the Kick? Before I spend the money, I'd like an opinion. Thanks
When checking the ST300 with the adapter I did see a potential problem. The ST300 stranded wire cutters found at the base of the pliers could be damaged by the UTA. With the handles closed & the adapter in place the stranded wirer cutters can grip the adapter & MIGHT damage the cutters
Thankyou for the photos. VERY HELPFUL!
