Hopefully I'll have one to play with soon to see what all the fuss is about
As for the tools, well I have 3 PowerLocks, a PowerPlier, a PocketPowerPlier, a ToolClip, a Micro ToolClip, ParaTool, SwitchPlier, CrossGrip, CrossCut... Nuff Said!Def
Technically speaking, I think the change from scissors to V Cutter makes it an S-62. I don;t see much point in labeling the various implement configurations in a tool that has user interchangeable implements, but I suppose it makes inventory control a little easier at SOG.Def
I know that feeling- what are your observations on the V-Cutter? Any particular reason you switched?I like the V Cutter myself, but I'd never substitute the scissors for one (on purpose- I do have a factory S62) because I think that it should be illegal to produce a multitool without scissors...Def
Quote from: Defender on November 25, 2007, 02:25:59 AMI know that feeling- what are your observations on the V-Cutter? Any particular reason you switched?I like the V Cutter myself, but I'd never substitute the scissors for one (on purpose- I do have a factory S62) because I think that it should be illegal to produce a multitool without scissors...DefIts always to amazing to see how different people use and view these tools, any of em for that matter. I personally could care less if any of my multi's have scissors, its way down on the must have list when I buy. I just dont use em, but then someone like my wife uses hers almost everyday, its totally dependent on what you do day to day I suppose.
