Pentagonlight L2 to trade - Traded 2298
Global Tuffy Absolute Zombie Club Posts: 28,078 Just Awesome! And a Slayer of Polar Bear!
« on: November 16, 2007, 06:31:01 PM »
Hi all
Thanks to the previous EDC swap topic I was lucky enough to receive a L2 from eodtech.  Anyway long story but I now have 2 so 1 is up for grabs.
Description
L2 LED Light is a military-grade LED light for tactical operations. L2 utilizes a high powerful LED as the light source. It is regulated by electronic circuitry and engineered to be the high-tech flashlights of the 21st century. The sophisticated onboard electronics regulates the current delivered to the LED to ensure maximal brightness while sustaining the duration of peak brightness. LED is power efficient and does not need frequent lamp replacement since it will not burn out like the filament of incandescent bulbs. With this efficiency and our gold plated mechanism for optimal heat management and electrical conductance, L2 has a runtime of at least 90 minutes at peak brightness and at least 3 hours of usable light output with diminishing output. With maximal 85 lumens of eye-blinding maximal focused white light, L2 is a great tactical light for close quarter combat and room-to-room searches. Powered by two pieces of 10-year shelf-life CR-123A lithium batteries and a shockproof light source, L2 is also an ideal flashlight as part of emergency preparation kit. Our proprietary textured reflector is designed for focusing the light generated into a smooth intensified light beam. L2 is preconfigured with TC4 push on/off PentagonLight™ signature tail-cap switch. The extended long throw of our tail button switch can easily press slightly for momentary on while allowing click to constant on. The anti-roll pentagonal shape tail-cap makes it easy for one-hand operation. The removable pocket clip can be taken off easily for carrying the light in a holster. Crafted out of aerospace grade aluminum tube using precision CNC machine, L2 is rugged and tough for the toughest environments. The exterior of L2 is in our anti-reflective, anti-corrosive, and anti-abrasive Military Spec Type III hard anodized exterior finish. All connections are sealed with double O-rings for fail-safe protection against water leakage. L2 is not just a limited use LED light, since its head is interchangeable for alternate light sources from a diverse selection of conversion heads available separately, so your initial investment for a high quality flashlight is maximized.
The flashlight has been used but there are no signs of this whatsoever.
Please note that no batteries will be included nor will the clip which I have stolen off it for my original one.  It does however come with the original cardboard sleeve that explains battery insertion and usage etc.
I am looking for anything really so please do feel free to send me your offers.
Thanks
Benner
« Last Edit: November 25, 2007, 10:26:44 PM by Benner »
Re: Pentagonlight L2 to trade
« Reply #1 on: November 17, 2007, 10:53:30 PM »
I do have a soft spot for retired Leathermans if that's any help.  ;)
No Life Club Posts: 2,887
« Reply #2 on: November 18, 2007, 02:19:44 AM »
Quote
Don't we all.  :D
Sr. Member Posts: 388 VICTORINOX
« Reply #3 on: November 19, 2007, 06:59:21 PM »
e-mail sent!!! :multi:
Enjoy!
« Reply #4 on: November 19, 2007, 08:55:45 PM »
Sent you an email in reply.
« Reply #5 on: November 20, 2007, 12:52:55 AM »
No longer on hold so is still available!  :)
« Last Edit: November 20, 2007, 11:37:03 PM by Benner »
« Reply #6 on: November 24, 2007, 11:52:02 PM »
Reserved until further notice.
« Reply #7 on: November 25, 2007, 10:26:14 PM »
This has now been claimed by another member.  :sak:
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $43.49
PayPal Fees: $2.52
Net Balance: $40.97
Below Goal: $259.03
 14%
June Donations
Page created in 0.033 seconds with 32 queries.
© 2018 Defender Web & Tool
