Login
Register
Menu
Home
Help
Forum
Tool Talk
Swiss Army Knights Forum
111mm blade lock up
111mm blade lock up
Guardian
5 ·
1460
« previous
next »
Print
Pages:
1
Go Down
Guardian
Hero Member
518
Unless
111mm blade lock up
on:
May 21, 2011, 05:20:13 PM
Hi gang, looking for some reassurance....all, bar one, of my 111mm liner lock SAKs (and I currently, sadly, have 11, which include Centurions, GAK, DAKS, Tekkers, Soldatenmessers, age range from the 1990's to 2010) have some up/down movement when the blade, large screwdriver or belt cutting blade (on the dual pro) are opened. None, apart from this one Trekker, are
rock
solid like my ALMAR SERE 2000's. I also have a couple of Wenger new Rangers and their blades also give a lot....in fact more than the Victorinox's. This must be a deliberate thing then?
"Unless someone like you cares a whole awful lot, nothing is going to get better. It's not."
― Dr. Seuss, The Lorax
felinevet
Banner Member
No Life Club
1,537
Re: 111mm blade lock up
Reply #1 on:
May 21, 2011, 06:35:38 PM
Actually, the exception is the one that locks up tight. The vertical play is built in and entirely intentional. These are working knives and not tacticals so they don't need the same tight lockup. The locks are very safe.
T
Sea Monster
No Life Club
4,249
Reply #2 on:
May 22, 2011, 06:14:48 AM
Nothing to worry about.
As I understand it, the Backspring still holds the blade in place in the 111mm models, not the liner lock, so there is no need for the liner to be pressed against the blade, but from what I've read on here, and my own experiences, the liner lock is still as safe as any.
For what it's worth, the play on mine is pretty much unmeasurable. It'd be less than a thou.
ICanFixThat
No Life Club
4,534
Reply #3 on:
May 22, 2011, 04:41:38 PM
I would not say it is built-in, or intentional. I'd say it's within the specs/tolerances of the design, as the design did not consider absolute tight lockup as a goal.
Guardian
Hero Member
518
Unless
Reply #4 on:
May 22, 2011, 05:12:23 PM
Thanks guys
. Thinking about it, it's as you say. The backspring holds the blade/driver in place and the linerlock is purely a safety feature and not a 'lock' pur se. Also, having the linerlock slighty loose, means its easier to push out of the way to close the blade/screwdriver.......
Now feel much happier
Print
Pages:
1
Go Up
Forum
Tool Talk
111mm blade lock up
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$168.99
PayPal Fees:
$9.87
Net Balance:
$159.12
Below Goal:
$140.88
Site Currency:
USD
53%
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
