Login
Register
Menu
Home
Help
Forum
Tool Talk
Swiss Army Knights Forum
Sideways play on 111mm Hunter
.banjo.
7 ·
1902
« previous
next »
Print
Pages:
1
Go Down
.banjo.
Newbie
6
on:
May 22, 2011, 09:28:57 AM
Hi all, I am new here but have been kicking around on the forum reading for the last week so I hope to get more involved! Now my 111mm Hunter which I got in 1995 when I was 10 (yes I am surprised I never lost it!) has some sideways movement on the blade, is that normal? It's not a great amount but enough that if you hold it up to the light you can see a small gap appear between both sides as you wiggle it. None of the other tools do this but none of the other tools lock so maybe there is something in that. It may have always done this but I can't be sure. For those interested it is a red Hunter without the Deer and cost me $35 (around $19 usd?) back then. Of course I had no job or practicle reason to have one back then but it helped me build cubby houses!
I have a Vic Sportsman on the way (after seeing peoples opinions on here of a good edc and what I would personaly get the most out of) and I also have a leatherman kick already. I fear I might have to start buying more though the more I read around here
ICanFixThat
No Life Club
4,534
Re: Sideways play on 111mm Hunter
Reply #1 on:
May 22, 2011, 04:38:12 PM
Does not seem right. I'll try to find a hunter model specificly to check.
felinevet
Banner Member
No Life Club
1,537
Reply #2 on:
May 22, 2011, 05:40:41 PM
Vertical movement is normal, sideways is not.
T
Guardian
Hero Member
518
Unless
Reply #3 on:
May 22, 2011, 07:24:47 PM
Yep, as the gentlemen have said, sideways movement is a no no.Your hunter has probably had a hard life!!!
"Unless someone like you cares a whole awful lot, nothing is going to get better. It's not."
― Dr. Seuss, The Lorax
.banjo.
Newbie
6
Reply #4 on:
May 23, 2011, 07:56:43 AM
What's vertical play? Movement back against the lock?
I don't believe it has had a hard life i.e. I never used the blade to pry with. Perhaps I will have to strip and repair? Are replacement scales an option for slide lock models?
Eyegor
Full Member
111
Reply #5 on:
May 23, 2011, 07:23:24 PM
I do not treat my Hunter gently and I have no sideways play. Any sideways movement I generate is actually the liners or scales flexing minutely under the lateral pressure.
T
.banjo.
Newbie
6
Reply #6 on:
May 24, 2011, 05:27:04 AM
Thanks Eyegor, perhaps I should have been more clear. The blade only moves under pressure, it is not loose in that it wobbles or anything like that. So perhaps that is to be expected then.
Print
Pages:
1
Go Up
Forum
Tool Talk
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$158.99
PayPal Fees:
$9.20
Net Balance:
$149.79
Below Goal:
$150.21
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
