Quote from: Ashley on May 24, 2011, 02:28:01 AMLocking ring can easily be removed. This is video by my UK friend. thanks ashley for that, looks pretty easy to remove and fit back on, now my options are open
Quote from: Zed on May 24, 2011, 09:04:49 AMQuote from: Ashley on May 24, 2011, 02:28:01 AMLocking ring can easily be removed. This is video by my UK friend. thanks ashley for that, looks pretty easy to remove and fit back on, now my options are open And you have one here http://forum.multitool.org/index.php/topic,27717.15.html
I've found that no tools are needed to remove the lock. Simply close the blade, turn the lock so that the blade is locked closed, and then firmly but carefully open the blade. This forces the lock off, usually sending it flying across the room.
