Me like! Me like!!
I think Shane has raised the bar , cast pliers multi's will become obsolete ( not a bad thing IMVHO ) . Chris
I do agree that a drop-forged plier head would be strong. However, the high initial cost of the forging dies makes it unlikely we'll ever see a multitool made using this method.
As regards Cast -versus- Cut from Billet, if all else is done correctly (grade of steel, heat treat, etc) then the billet pliers should be inherently stronger. This is because the grain structure of the raw barstock was rolled and formed at the steel mill, making it stronger. Whereas the grain structure of a casting is random and crystal-like, which makes it more brittle.
Discussion aside, it will be cool to have a MT with a billet head
Have you guys ever deformed a lip?
I never have.Actually I have more of a problem of springing / stretching the plier rivet than deforming the lip. I would say this is at least 50% of the reason for my Wave warranty returns.
I was wondering because it seems a bit thin (about 1mm), but then again, I don't know much about material strength/structural integrity
