CRKT IGNITOR TACTICAL KNIFE 6860 - USD 34.99
The Ignitor raises the bar for all value-priced folders, by using premium blade steel, layered G10 scales, and patented features including assisted opening, a unique knife safety and our special serrations. Consider these features: First the blade. Its a modified drop point design with a high hollow grind. We use premium 8Cr14MoV stainless steel. The frame uses our rigid InterFrame build with stainless steel liners, one locking, and layered G10 scales, textured and CNC machined to aid grip. The deep finger choil and pommel fit the hand nicely. The flat cross-section makes for comfortable in-pocket carry. The true breakthrough is our ability to combine our patented OutBurst assisted opening with the patent-pending Fire Safe mechanism. When closed, the blade is safely locked by the Fire Safe pin. It cannot be opened until the safety button on the end of the thumb stud is firmly depressed and the thumb stud is nudged outward. Then the blade springs open instantly for use. Yes, this is a design for right-hand opening, but it is the best integration of folder safety and fast access that we have ever seen in a sport and work folder. Caution: When closing the knife, always press firmly to
http://www.edcsource.com/auction_details.php?auction_id=107868
