Need blade/saw/serrated blade/file dimensions of wave/charge
be Offline Rebelgium
I'm doing research for a mod, I'm trying to find out if it'd be possible to fit a SOG wire stripper in the place of the saw or serrated blade in a LM wave/charge.
If you have a wave or a charge, can you plz measure the
-Width
-Length
-Depth
-hole diameter
Of the biggest of these four tools: blade/saw/serrated blade/file.
Thanks!
gb Offline Tofty
Re: Need blade/saw/serrated blade/file dimensions of wave/charge
Reply #1 on: August 08, 2011, 04:40:03 PM
If you can read cad files i can send you the drawing i did for my own blade mod.
But these are the basic blade dimensions i worked from:
Width-2.4mm
Length (from centre hole)-81mm (overall)-85.5
Depth (from front to centre hole)-7.5mm (overall)-17mm
Hole diameter-5.66mm
The overall depth includes the thumb hole which means the blade sticks out of the housing.
The overall depth of the file or the saw is-15.3mm
Reply #2 on: August 08, 2011, 05:29:02 PM
That's very helpfull, thanks!
Total Receipts: $66.45
PayPal Fees: $3.99
Net Balance: $62.46
Below Goal: $237.54
21%
