Lets see..... Where did I put that....(Image removed from quote.)The one up top with the streamer is a 91mm Climber, the one below it is an 84mm Climber Small.
Here you go. This should help you.http://www.vendian.org/mncharity/dir3/paper_rulers/
Quote from: Chako on August 13, 2011, 09:59:54 PMHere you go. This should help you.http://www.vendian.org/mncharity/dir3/paper_rulers/Ar you kiddin me I want to see SAKs side by side I dont want rulers
Suit yourself. I personally find those rulers very handy for those times when I am unsure the difference a whole 7 mm make.
StayGlow 91mm Climber with Red Cellidor 84mm Climber(Image removed from quote.)The way they are sitting it is not much help for size comparison, but I had it uploaded. 93mm Pioneer with 84mm Golfer(Image removed from quote.)A mix of 84mm, 91mm, & 93mm SAKs(Image removed from quote.)
(Image removed from quote.) 91mm on left, 84mm on right.
(Image removed from quote.)91mm on left, 84mm on right.
Before I decided to buy my Wenger Scout, I thought of buying 111mm. Fortunately, I haven't bought it cos it's too big for carrying in a pocket.
