Welcome to the forum! I also recommend the Explorer - you get the Philips screwdriver as an added bonus.
Quote from: sawman on August 19, 2011, 05:14:50 PMWelcome to the forum! I also recommend the Explorer - you get the Philips screwdriver as an added bonus.Thanks Sawman ... your avatar is the the Explorer ?
I'd go with Kelly and the Sawman,and plum for the Explorer,especially the Plus option.If you feeling rich,or dont mind modding look at the Yeoman.Compacts are very carismatic little SAKS but they do lack a Philips...
And maybe mod with Voyager Lite Ruby Scales.
One last question .... before I take the plunge Is it possible to add a SAW unto the Explorer ?
no problem DocTrooper, if you want to get even more excited about mods, check this thread : http://forum.multitool.org/index.php/topic,5287.0.html
the magnifier/light combo while doable might be a little finicky as there is nothing that currently has that combo.
Actually, there is. Check out the Cybertool Lite. They do just this - (new) mag and LED lite in the same layer. The Phillips would be redundant since it's a Cybertool. DocTrooper - Sounds like now you want a Ranger w/ a LED/mag layer a la the Cybertool Lite. I'd still suggest starting with a Champion Plus (get one with a new mag glass & new metal file) and combine with LED from a Spartan Lite. Final size will be slightly wider than a Champion, so you'll need new pins. Given the size of the final knife here, I doubt you could start with a SwissChamp and reuse the pins... but the time they were drilled and everything, they'd be too short. New pin stock is dirt cheap, so don't let that deter you.
Doc sounds very much like you need to use the classic MTo approach to this:Buy several,field test them,love them all and start again!I have the Huntsman Light(Love the inline driver),built a Golfer using a Spartan Light as a basis,and found in dire straits(cue the music boys...)the built in LED is much better than usually thought(had to use it to help find my way arround rural York on a business trip after lending my torch,which I'd only taken as a gut feeling,to the girls in the party),but as folks here have pointed out before,fake Photon mini LEDs are cheap on ebay,and very effective.My Astronaut is my serios go-to SAK,usually theres a Photon,a glow in the dark paracord lanyard,and a water tight capsual with £10 in it.
