Surge T-shank holder...which blades fit best?
ca Offline Metropolicity
  • Hack Virtuoso
on: October 08, 2011, 01:16:17 AM
I just got some Makita jigsaw blades for my Surge (they came in black yay!) and they are super loose because they are half the thickness of the OEM saw and file...
anyone find or know of any saw blades (preferable metal 24 TPI) that fits it without any mods?
I may have to just cut one and stack the space in there to make it snug.
Why stop now?
Shapeways - Metro's Q-branch:
us Offline captain spaulding
Re: Surge T-shank holder...which blades fit best?
Reply #1 on: October 08, 2011, 01:21:02 AM
Put two saw blades side by side.  :think:  :D
I'm the milk man!
  • Hack Virtuoso
Reply #2 on: October 08, 2011, 01:47:00 AM
TWICE THE CUTTING POWER! haha.
48 TPI, wow.
I think I may have solved the problem, took some heat shrink tubing and did one layer on it. Seem to solve the problem...sort of.
Now to solve that crazy clip wooble and the Barrage and BOrrage will be my HEDC.
Why stop now?
Reply #3 on: October 08, 2011, 02:33:11 AM
48 TPI, wow.
Do you think the tubing will hold up to the constant opening and closing of the Saw? It might wear and become loose after some use. I could be wrong, but figured I would ask.
I'm the milk man!
  • Hack Virtuoso
Reply #4 on: October 08, 2011, 02:44:59 AM
48 TPI, wow.
Probably, I am pretty keen on keeping it in there for good. I have to cut off some of the saw (only about 7mm) and it'll close in there.
Besides, shrink tube is cheap and easy to reapply.
Why stop now?
ca Offline Beerplumber
Reply #5 on: October 08, 2011, 02:47:20 AM
I've also rolled this issue around in my head, of all (quite a few) the blades I've bought I haven't found any thing thicker, I used some electrical tape before but it's not really a good fix.  Haven't tried yet but I was thinking about a little super glue and a small shim on the shank, really the shim doest need to be the T shape.  I bought a pack of blades, I think they're like 6 or 8 inches long and maybe 8 tpi for camping but obviously folding them is an issue so they need to be carried separate. I also picked up some diamond grit blades for finagling granite, I think that's the thickest of the blades I've bought.  This being said without modding perhaps cutting the shank off one blade and carrying it separate, slipping it in whenever another blade is used.  If epoxy would stick to the shank maybe a dab or two on each shank would work.
Reply #6 on: October 08, 2011, 02:59:40 AM
Sounds like you already thought this out.  :tu:
I'm the milk man!
  • Hack Virtuoso
Reply #7 on: October 08, 2011, 03:45:14 AM
I wanted to know if there was options without resorting to my own modding solutions :)
Why stop now?
Reply #8 on: October 08, 2011, 04:13:38 AM
Sometimes its the only way.  :D
I'm the milk man!
00 Offline jim guy
Reply #9 on: October 08, 2011, 04:47:37 AM
Bosch blades fit the best out of the ones ive tried
us Offline MeadMaker
Reply #10 on: October 08, 2011, 02:54:51 PM
If I remember correctly, Bosch pioneered that style of connector for their jig saw blades.
Tick Magnet
us Offline Vadim
Reply #11 on: October 09, 2011, 07:55:40 PM
The thickness of the Festool blades is better than Bosch blades.  :tu:  ;)
« Last Edit: October 09, 2011, 07:57:14 PM by Vadim »
us Offline Accujohn
Reply #12 on: October 09, 2011, 09:33:26 PM
Are both those brands at Home Depot??? Or?
us Offline Vadim
Reply #13 on: October 10, 2011, 12:22:21 AM
I bought Festool blades from Woodcraft store http://www.woodcraft.com/default.aspx?keyword=woodcrafts&refcode=06INGOOG&gclid=CKKT6qrR3KsCFRdTgwodTDDTOw
us Offline Mike 56
Reply #14 on: October 12, 2011, 01:23:45 AM
Spray the blade holder with Pam cooking spray apply a generous amount of J-B Weld to one side of a blade put it in the blade holder. Remove it the next day clean it up a little and the blade will fit perfect.
Mike
Mike
Reply #15 on: October 12, 2011, 05:57:15 AM
Mike
Boo-yah. Sliced bread is jealous of that idea, suppose a dab of grease or motor oil might work too? I'm going to give it a whirl.
us Offline Mike 56
Reply #16 on: October 12, 2011, 06:55:52 AM
Yes grease or oil will work but cooking spray or paste wax will give you a tighter fit. I have been bedding rifle actions to stocks for years doing this.
Mike
Mike
us Offline Franimal
Reply #17 on: February 21, 2015, 10:07:52 PM
This topic is hella old and maybe even dead...But has anyone tried just cutting off the shank of a dull blade and throwing that 'shim' with a fresh blade to snug things up? Will it fit or too thick?
Reply #18 on: February 21, 2015, 10:15:17 PM
No thread is ever dead on MTO, just hibernating. ;)
And yes, too thick.
us Offline Kampfer
  • Tactical Desk Jockey
Reply #19 on: February 21, 2015, 10:27:51 PM
The blade exchanger of NEW Surge, a spring is added to solve this problem.
All blades tick or thin would fit in tightly, no side to side movement.
Reply #20 on: February 21, 2015, 11:35:25 PM
Only it doesn't, there is a lot of movement. I still use a heat shrink sleeve.
us Offline JAfromMn
  • Stranger in a Strange Land
Reply #21 on: February 21, 2015, 11:51:26 PM
So I'm using a old new surge because mine still wiggle.  :facepalm:
Defend the Hive!!!
nz Offline Syncop8r
Reply #22 on: February 21, 2015, 11:58:05 PM
And what about the saw blades?
us Offline Kampfer
Reply #23 on: February 22, 2015, 12:05:16 AM
Really? :think:
I had not experience this issue
Reply #24 on: February 22, 2015, 12:37:56 AM
Really? :think:
Yes for reals. And I'm not joking around like with Harley and the Micra.
us Offline Franimal
Reply #25 on: February 22, 2015, 08:59:52 AM
I have a new surge. and that blade exchanger is HOTNESS! but there's not a shimmering gleam of a flame in hell that my money manager (missus) would think it a good idea for me to hack open another one just for parts!  I am looking to try making my own for my mini surge. i don't know if i will try a similar style to the current one or modify it.
nz Offline babola
  • The Tinkerer
Reply #26 on: February 22, 2015, 10:15:15 PM
... my money manager (missus) ...
And just how did you get yourself into this situation?! :twak:
Run Forrest...run!
EDC and OCD. A wicked mix.
us Offline JAfromMn
Reply #27 on: February 23, 2015, 12:22:08 AM
The factory blade fit perfectly.  Off the shelf blades do not.
Defend the Hive!!!
us Offline Franimal
Reply #28 on: February 23, 2015, 02:43:43 AM
Run Forrest...run!
2 quads, 2 dirtbikes, 2 cars, 2 dogs, 2 kids....I'm thinking she's done with the doubling. although we do want to more 'lil-uns' sooo... :ahhh :facepalm:
nz Offline Syncop8r
Reply #29 on: February 23, 2015, 03:58:31 AM
So I'm using a old new surge because mine still wiggle:facepalm:
Sorry, you need to re-read it with your mind in the gutter this time.
