Charge mod
us Offline Agent X68
  • "My blackberry's not working" (see sig for video)
Charge mod
on: October 20, 2011, 03:26:48 AM
Hi all, I was thinking about attempting a charge mod and I had 2 questions.  1.  Will the wave/charge/blast scissors fit into where the can opener is on an XTI?  2. Can you just unscrew the botom screw of the charge and mod the inside tools without taking the whole tool apart?
Thanks,
Agent X68
Make a tool idiot proof and someone will make a better idiot. Also, Change is inevitable, except from a vending machine.
:)  See my personal text:
us Offline Crouton
  • "Live long and ..useful."
Re: Charge mod
Reply #1 on: October 20, 2011, 03:32:34 AM
Thanks,
Agent X68
I'm not certain  about the scissors fitting,  but yes you can take out the inside opening tools by removing the pivot and you don't have to remove the plier end pivot.
EDIT:  Yes I think you can swap the scissors in instead of the can opener, but I've never actually done that mod.  Maybe someone else will chime in. The best way way to find out is to try.
« Last Edit: October 20, 2011, 03:37:56 AM by Crouton »
ca Offline Metropolicity
  • Hack Virtuoso
Re: Charge mod
Reply #2 on: October 20, 2011, 05:38:27 AM
you betcha!
Give it a try, as long as the scissors sit, resting on the side of the tool you are clear, otherwise it would interfere with the plier head rest.
Why stop now?
Shapeways - Metro's Q-branch:
Re: Charge mod
Reply #3 on: October 20, 2011, 10:42:10 PM
Thanks for your help, charge is arriving tomorrow.  Any advice on how to remove the scisors from a blast?  >:D
Re: Charge mod
Reply #4 on: October 21, 2011, 02:38:03 AM
You can remove the knurled pivot screws by clamping on both ends with two sharp pliers, and unscrewing. :)
Re: Charge mod
Reply #5 on: October 21, 2011, 03:01:25 AM
Thanks.  Also, what size screw does the XTI have?
Thanks
  • Hack Virtuoso
Re: Charge mod
Reply #6 on: October 21, 2011, 07:30:50 AM
XTi's have a T10 Security Torx bit. Super easy to find, only one side rotates, the otherside stays put, so if you feel any resistance try undo the otherside. Once you've undone it, you'll see what I mean.
Why stop now?
Re: Charge mod
Reply #7 on: October 21, 2011, 01:46:13 PM
Thanks, it's 6 point, right?  On LMs website it looks to be 5 point.
Re: Charge mod
Reply #8 on: October 22, 2011, 02:18:06 AM
Disregard my last post, it is 6 point.
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $160.46
PayPal Fees: $9.45
Net Balance: $151.01
Below Goal: $148.99
June Donations
