What do you do to look after your flash light?
gb Offline ryan1835
  • buh
on: October 23, 2011, 08:35:30 PM
Im thinking keep it in a case of some description. Another idea i was toying with was, to put a clear piece of film over the lens to prevent scratches. Any other ideas?
I
gb Offline Millhouse
Re: What do you do to look after your flash light?
Reply #1 on: October 23, 2011, 09:21:05 PM
The only thing I do is lube the O rings.
Reply #2 on: October 23, 2011, 10:03:32 PM
I just make sure they are clean and dry when they get messed up, and also lube the thread too.
gb Offline Farmman
Reply #3 on: October 24, 2011, 12:29:41 AM
What the two above said.
us Offline Chain Gang
Reply #4 on: October 24, 2011, 01:12:01 AM
I do the above and about once a month I inspect the battery for leakage.
Reply #5 on: October 24, 2011, 01:21:13 AM
When the boys were younger I had to strip them down regularly and wash out the drool :D
These days the threads get a wipe and relube about once a year and that's that.
us Offline gustophersmob
Reply #6 on: October 24, 2011, 01:30:45 AM
+1 on lubing the threads.
If the lens is glass, chances are it won't scratch easily.  For polycarb or some other plastic, a clear film may help, but it will reduce the output a little.
Reply #7 on: October 24, 2011, 01:56:02 AM
Whenever I get a new light, the first thing I do is break it down and clean all of the factory lube out of it.  I typically use De-Oxit, but rubbing alcohol does fine too if there's not built up gunk.  I make sure to clean all the contact points, first with a white eraser, then alcohol or de-oxit on a q-tip.  After that, I run the tip of a pick lightly through the threads to remove any left over flash from machining and do another quick wipe-down with alcohol.  I also wipe off all the o-rings as well.
Once that's all done, I put a generous but not gratuitous amount of nyo-gel in the o-ring slots and on all threads.  I seat the o-rings in first, and pull them around at least a full 360º to make sure the nyo-gel is properly distributed.  Then put it all back to together.
I do the same when I get new tools that aren't too complex or intricate, and if I was into guns, I'd do the same thing for them as well.  I'm not a gun nut, but I am planning on getting a shotgun, and when I do not only will I take the necessary training and safety courses to use it properly, but also take any classes I can find on how to strip, clean, and maintain my weapon when I get it.
ni-ulster Offline cerbera147
Reply #8 on: October 24, 2011, 02:49:43 AM
Fenix have a good but boring video on light maintenance  :tu:
I'm like everyone else; clean & lube the threads and clean the contacts :)
I use this from Halfords.
http://tinyurl.com/69brhqf
Offline Styerman
Reply #9 on: November 02, 2011, 07:03:43 PM
I clean and lube the O rings , and clean the threads . With AAA , check the tube often for leakage .
Chris
Reply #10 on: November 02, 2011, 07:06:48 PM
Clean threads, lube o-ring and check for battery leakage.  Do the lights I carry every day about once every 3 months.
Oh, and don't be a tart with some film!  :D
Reply #11 on: November 02, 2011, 09:40:24 PM
I have a little rubber cap on my ITP as its often in my pocket with my change
 :salute:
Reply #12 on: November 02, 2011, 09:46:56 PM
Benner's top tip of the day...
If you remove that cap, it'll be much brighter.
Thanks for listening.
Reply #13 on: November 02, 2011, 10:00:59 PM
Reply #14 on: November 02, 2011, 10:01:54 PM
Thank you, thank you. I am here all week.
gb Offline Mike C
Reply #15 on: December 28, 2011, 09:21:27 PM
I just keep mine in a display case but most important of all i dont leave batteries inside them unless i am going to test them, battery leakage is death to torches in some cases as it eats the contacts an the switch. It can also take the coating of the reflector surface to.
gb Offline 5hif7y
  • tooled up
Reply #16 on: December 29, 2011, 12:48:28 AM
i feel silly saying it but till now didnt even think about flash light maintenance. i clean and oil my leathermans, SOG's and SAK's but didnt even think about lights.
thanks for the enlightenment  :salute:
-----5hif7y-----
gp Offline Nightshade
Reply #17 on: December 29, 2011, 12:55:25 AM
Good primer on flashlight maintenance... I use the Caig products on so many things.
http://www.flashlightreviews.com/features/care.htm
gb Offline 5hif7y
  • tooled up
Reply #18 on: December 29, 2011, 01:03:53 AM
thanks nightshade  :tu:
-----5hif7y-----
ca Offline Beerplumber
Reply #19 on: December 29, 2011, 06:28:23 AM
 :salute:
I think that's a great idea. Where did those caps come from they look familiar :think: I was considering that 3M film being used for screen protectors on cell phones lately. I have it in my iPhone (ghost armor?) and have seen it on cars and other places. It seems really clear. My aaa maglight lens is toast from scratches.
Stay multi my friends
ca Offline Metropolicity
  • Hack Virtuoso
Reply #20 on: December 29, 2011, 10:13:39 AM
 :salute:
Look at vinyl chair leg floor protectors. The one in the pic looks like a conduit cap or something.
Why stop now?
Shapeways - Metro's Q-branch:
au Offline mvyrmnd
  • Tupperware Hunter
Reply #21 on: December 29, 2011, 10:38:50 AM
I don't :)
Reply #22 on: December 29, 2011, 12:53:46 PM
Some kinds of machines are sent out with these on the back protecting multipin plugs/sockets
And some kinds of drums of cable have something similar
Maybe you know someone in the electronics industry  :think:
I used to have one on my AAA Maglight for years until I lost it  :(
us Offline MirrorEdge
Reply #23 on: December 29, 2011, 02:50:57 PM
Dry it
And change the batteries
