Most pliers based multitools have an 1cm cutting area, but only the first 3mm (the notch) is hardened enough to cut hard wire, SS nails etc.
I understand that the notch is placed there since this is where you would get the maximum torque and thus the maximum cutting force.
I also realise that you could not harden the whole head as that could make it more fragile (less elastic) and more likely to crack if it gets hit or twisted.
What I wonder is, why not harden the whole cutting area, the full 1cm.
What are you going to cut with that, less hard, area that needs it to be softer than the notch?
Is it to protect it if it gets twisted?
Is it so that the manufacturer limits the size of hard metal you can cut, thus protecting the tool?
This is even more bizarre in the supertool 300 which has replaceable cutters, made from a harder metal and still has that specified hard wire notch.
Any explanations?
