New oiling technique.
us Offline Chain Gang
on: November 16, 2011, 12:20:19 AM
I have a large bottle of mineral oil to lube my mt,knifes etc.The problem was getting the oil from the bottle to the tool.I started out with a eye dropper but what a mess.I had a 6 inch plastic cable tie laying on my work area and the light bulb lit up.I dipped small end of the cable tie in the oil,let the excess drip off and inserted it near the pivot points.The oil wicked in at the exact place I wanted it and no mess at all.Try it,you will like it.
Re: New oiling technique.
Reply #1 on: November 16, 2011, 12:58:37 AM
Not a bad idea.  I often use some regular cotton thread- soak it in oil and "floss" the pivot point to get the oil right in there.
ph Offline edap617
Reply #2 on: November 16, 2011, 01:13:16 AM
Thanks  for the tip, Chain Gang.
um Offline Mr. Whippy
Reply #3 on: November 16, 2011, 01:27:25 AM
I do a similar thing with a wooden shishkabob skewer.  :tu:
ca Offline Sean
Reply #4 on: November 16, 2011, 02:45:53 AM
good idea's there, thanks for the tip. :tu:
us Offline THE_LONGBOW
Reply #5 on: November 16, 2011, 03:07:58 AM
I use a QTip (cotton swabs)
ca Offline jzmtl
Reply #6 on: November 17, 2011, 10:17:34 PM
I've always used a 1cc syringe with sharp needle tip ground off so I don't accidentally stab myself, they are maybe 40 cents at your local pharmacy.
us Offline Vadim
Reply #7 on: November 18, 2011, 06:57:36 AM
Same here  :),use a QTip (cotton swabs)  :tu:
il Offline Threeme2189
Reply #8 on: November 18, 2011, 05:39:50 PM
My Leathermans tend to rust. I guess it's my sweaty hands or the environment here...
So I go all out and coat the suckers with oil, and then I wipe off some of the the excess.
us Offline Singh
Reply #9 on: November 19, 2011, 03:59:18 PM
 :tu: So do I.
de Offline Jmora
Reply #10 on: November 19, 2011, 04:04:02 PM
I use the toothpick of a SAK. works perfect for me.  8)
us Offline Rooster
  • Tools are extensions of ourselves... share a tool.
Reply #11 on: November 20, 2011, 04:49:48 AM
I use a product called Bluecreeper...it used to be called Rustreaper.
It is the best, and comes in a small bottle with a needle nose applicator.
Check it out!  You will never go back!
Rooster
http://www.bluecreeper.com/
http://www.bluecreeper.com/ecom-prodshow/bc001.html
"They talk about creating millions of "shovel ready" jobs, for a society that doesn't encourage anyone to pick up a shovel."  ... Mike Rowe
us Offline Rooster
Reply #12 on: November 20, 2011, 07:44:25 AM
UPDATE:
I recently purchased a Leatherman ST300.  And right out of the package I thought that the hinge was a bit tight, and it would stick when the jaws were fully open.  I used the Bluecreeper with the needle applicator, and now it feels better with less resistance...but then again I don't know how it is suppose to feel like, since this my first experience with a Leatherman.
Rooster
us Offline Mercury
Reply #13 on: November 23, 2011, 07:35:14 AM
I do the same thing.  I typically oil my tools while watching TV, so I just coat the pivot ends and fiddle with the tool and a paper towel until I don't see any residual oil.  It's pretty humid here even in winter so I have to be careful.  That said, my tools live in their leather sheaths and I have yet to find any rust on them if they are kept oiled.
us Offline Ashley
  • AKA Knife Crazied
Reply #14 on: November 25, 2011, 05:37:11 AM
A paper match also works wonders.
us Offline Mercury
Reply #15 on: November 25, 2011, 02:29:31 PM
Never thought of a paper match, but I have to try it now.  Sounds like it would work great.
