The pen and pencil thread
enki_ck · 323 · 45528
us Offline Enginears
Re: The pen and pencil thread
Reply #300 on: September 26, 2023, 01:46:46 AM
That 09’s got to have some heavy hold to it, when I was in drafting I used to use and I still have it, yup, my 03, that thing would break idk how many times, I had to have a very easy hand, yet I was also taking plumbing so I also had to have a very strong hand, not an easy mix, most of the others stuck with a norm size yet I think one other kid went to a 05, of course him and I had some of the sharpest drafts, at he end of the year we had to draft the teachers house and then put in a heating system, everyone played simple, yet of course me with the thinnest lead put in a subfloor heating system, (pretty much a line every like 8in, yet in scale was like every 1/4”) yeah NUTS! But I scored a 105 on it..
That sounds amazing. I like that pencil too, an 03 is impressive. I have such a heavy hand even with 05 I end up getting in the zone and snapping the lead, though I do like those thinner lines. I never actually drafted, though I wish I had. we would do all our drawings and stuff with CAD.
Reply #301 on: September 26, 2023, 04:27:16 AM
I did 7yrs of classes in drafting, even had my own drafting table at home for 6 of those, just a plain wood table with a nice metal edge and a pencil rest at the bottom, nothing fancy like a mechanical arm or floating t-square, just 1-t-square, 2-plastic squares, and 2-scales, although I did get fancy the last month of high school, I bought two solid aluminum squares and two aluminum scales, one 6” and one 12”, when I went to college the 12” hit the like marble table and the kid sitting next to me asked if he could see it, I was like sure, so I handed it over and he’s like wow this thing could be a weapon, I was like tell me about it, I don’t have that one anymore, but still the 6” along with the two aluminum squares and a plastic 12” scale, CAD, forget it, I think I tried it once, I’m totally old school, my unique thing is if you give me the side, front, and top, I can 3D draft it, it’s something I can do in my head,, when I took a state placement test to figure out what to do, I got every question right on the pic part, only one other person had ever done it before me, and of course it said I should do drawing or photos,, odd..
Reply #302 on: April 14, 2024, 02:32:15 PM
Ok, I’m bumping this subject, I want to change things up a little, I carry my cheap Pokka pen which is great, I switched the ink out of it with a bic, at first a like 1.6 which was great but dried up so quick, then to some other bic which was suppose to be like and endless ink, and it’s good, but I’m thinking of switching to lead, something that does NOT dry out and you end up putting a hole in your notebook trying to get it to write, I want to switch up my edc notebook, I currently carry a custom made mini composition notebook, in a leather cover, the reason it’s custom is because it’s dot graph vs lined or graph, I couldn’t find them in dot graph so I had three books made to fit my leather cover, but I’m thinking of switching to the normal 3-1/2 x 5-1/2” book which dot graph is easy to find, I want to get a nice cheap cover with a place to put your pen/pencil, but most of all I want to switch to lead, but idk what’s a good pocket pencil? There’s these new style carpenter pencils which have diff colors and will write on anything, but I can’t find anything nice, and I just spotted the rite in rain’s mechanical but it’s over 6” so it would be sticking out of the leather cover, so does anyone know of something simular? And around a 2. Lead and not that 5. Something, cause I have one of those and it’s a little too big! Suggestions?
Reply #303 on: April 15, 2024, 03:28:14 PM
I use pens much more than pencils these days (and with the rise of computers and smart phones, I don’t use either as much as I once did).
But here are a few to maybe check out…
Someone on this forum (I can’t recall who, or I would give credit where it’s due) turned me on to the Pentel P209.  It’s a really good pencil, but I measure it at about 5 5/8” so maybe still longer than what you want.
As another option, I don’t own one, but Parker makes a Jotter mechanical pencil that is nearly identical to their popular Jotter pen.  It’s a classy, timeless design and it is also shorter than many competitors at right around 5”.
Reply #304 on: April 15, 2024, 05:59:07 PM
Thanks, I always wanted a Parker jotter, so of course going pencil is an idea but it’s a low lead size, I need above 1.0mm, this is what I’m thinking of going with and I carry it in my back pocket so yeah there’s going to be stress on the pencil since it’s going to be in that slot of the leather cover,, now I did find these yet the one I really like is that all metal one, but I can’t find any info on it except I can only find it on Walmart for $7, so it’s probably junk, now that one above it is a rite in the rain and is a 1.3mm, and I can switch the lead out for red which I’d rather use cause I want something I can use on both paper and other things, just like that last one, thats a 2mm, and a carpenter pencil, so yeah writes on everything, but I don’t think it will fit in that leather holder,
Now one that would be perfect would be a metal scriber, solid metal, smaller, good grip, but just no lead, I did make a little something a while back, I took one of these and replaced the tip, I took one of those rattlesnake BB gun pellets and put it in place to act as one of those endless ink, and if I remember it did somewhat work, yet I just found it and it had an ink cartridge in it, (didn’t work) but huh, I wonder if I could put a piece of lead in it and make it a pencil, cause I just might have made my perfect pencil, including a magnet on the other end!
* IMG_3866.jpg (Filesize: 55.64 KB)
* IMG_3869.jpg (Filesize: 62.37 KB)
* IMG_3872.jpg (Filesize: 30.87 KB)
Reply #305 on: April 19, 2024, 06:28:07 AM
Always carry my Field Notes and my Pilot Prera.
Reply #306 on: April 19, 2024, 12:24:40 PM
Nice! :tu: I saw the rite in the rain calendar which is 3.5 x 5.5, it has each week on one side while a dot graph on the other and I thought that would be perfect, only thing is it’s already mid April, that and the only place that is selling it is (rite) and yeah it’s like $15, yet to ship it it’s another like $15,, like dang,
The other thing is I want to switch my edc pen to a pencil, I like their special pencil but I want to put it in a leather case since it’s going to be longer then the simple folding pen I carry now, only thing is it’s going to be in the back pocket, so idk if carrying it there if it will break?
es Offline microbe
Reply #307 on: May 29, 2024, 06:04:42 PM
Some pen and pencils! Most is vintage stuff from the nineties, but all with working refills and used regularly. Besides the pencils, I got a range of colors in these ones. Blue, black, red, orange (Octopus orange), and light blue (Kaweco Paradise Blue).
Beside 2 cheaper plastic ones, all of these have brass and steel components, and can be used as tactical pens any time.
I have a modern bolt action brass pen, but after the honeymoon it was dumped to the drawer and hasn't been used.
What can I say. I am a Rotring fan.
@blackdiamonds_edc
Reply #308 on: May 29, 2024, 06:27:50 PM
Like the 3in1, every Monday-Friday morning we used to have to fill the shelves, if there was an empty spot on the shelf someone would scan it and our department would get paperwork back each morning m-f, so we would have to fill the spot with what was missing if it was in stock, so what I would do was, if I found the item, check it off in blue, but if I couldn’t find any to fill the spot check it off in red, then the upper management would have to walk the department and check, they loved doing mine cause by doing it in two diff colors they would fly through only checking the red marks not caring about what I checked in blue, I should still have that pen somewhere, it was a 4in1, three diff colors plus a pencil,,
es Offline microbe
Reply #309 on: May 29, 2024, 06:42:21 PM
The 3in1 is actually a recent one, the only one not older then 25 years. Somehow a original German writing tool brand now is getting new editions, but made in Japan.
And yes, keeping track of lists and using colors to strike items off is the best use for multi color pens.
@blackdiamonds_edc
Reply #310 on: May 29, 2024, 07:01:08 PM
Here’s one of the 4in1’s, idk where the other took off to, as you can see it even has an eraser for the pencil,
* IMG_4102.jpg (Filesize: 121.91 KB)
es Offline microbe
Reply #311 on: May 29, 2024, 07:25:03 PM
Verry nice.
4in1 + eraser are 5 features. How is that for a multitool haha!
As for my simple 3in2 (no eraser), sometimes it is form over function, and this is one of those cases :-)
@blackdiamonds_edc
Reply #312 on: May 29, 2024, 07:33:36 PM
Well if you want to put it that way, pencil plus pen would totally be multitool, if it was just diff pens it would make it not multitool but multicolor! :rofl:
es Offline microbe
Reply #313 on: May 29, 2024, 07:50:36 PM
I used to have one of those 4 color bic's.
It was pretending to be a multitool, but ultimately, it was just multicolor pretender.  :twak:
@blackdiamonds_edc
Reply #314 on: May 29, 2024, 08:48:56 PM
Those were great, I just hated the little ball at the top, I’d just cut it off and file it smooth..
wales Offline Smashie
  • Smurf it!
Reply #315 on: June 25, 2024, 11:54:20 PM
My current daily driver. TWSBI Eco pen in sapphire with Diamine Bilberry ink.
Si vis pacem, para bellum
Reply #316 on: June 26, 2024, 05:37:22 AM
Reply #317 on: June 26, 2024, 11:59:49 PM
Me, too!
us Offline GreyFox
Reply #318 on: June 28, 2024, 01:38:55 AM
Here's a couple of vintage mechanical pencils that I found after my father died, both gold filled.
The green one is a Parker with a 5-16 pat. date on it.
The gold one is a Sheaffer's with a 11-5-18 pat date.
* Vintage pencils 3.jpg (Filesize: 106.44 KB)
us Offline GreyFox
Reply #319 on: June 28, 2024, 01:40:18 AM
* vintage pencils 4.jpg (Filesize: 83.07 KB)
Offline 3.0TD
Reply #320 on: June 29, 2024, 01:29:14 AM
I love titanium
nl Offline Serena
Reply #321 on: October 27, 2024, 06:52:07 AM
Bought a Lamy ST Steel fountain pen. Writes so smooth!
Reply #322 on: November 05, 2024, 02:54:03 PM
As I mentioned before I was thinking of switching, but something else got me thinking, rather then switching from ink to lead, why not switch to electronic? I just can’t find what I’m after, in the pic I posted there only like $15, but what you see is what you get, write it down and when your done turn it off, yet when your done with the page you just hit a button and poof, the whole things gone, nothing with memory, so you can’t save anything, I’d sooo like something like this that fit in a like 3.5 x 5.5 cover that you could save certain things, anyone have any clue of these?
* IMG_4699.jpg (Filesize: 94.23 KB)
November Goal: $300.00
Due Date: Nov 30
Total Receipts: $90.00
PayPal Fees: $4.84
Net Balance: $85.16
Below Goal: $214.84
28%
November Donations
