Got Paracord?
Splat · 2382 · 354692
gb Offline Essexman
Re: Got Paracord?
Reply #510 on: May 19, 2010, 02:14:18 PM
Essexman,
What kind of knot did you use to finish the loop on the leash?  That's really quite nice. I made a couple for my dogs but finished them differently.  Those are really quite good!   :tu:
 oh this could be tricky. Now at this point I would normally give a link or two showing how to make that knot, but it came from a book!  The book says it's a crown knot followed underneth with a wall knot.  This is after the 4 ends have been weaved back through the 4 cords to make the loop for the handle.  It's a pain to finish neat. I pulled the knot tight, cut and sealed the four ends as short as possible, then pulled the ends backwards into the knot to hide them. This left a bit of slack in the knot, so I then worked the knot tight in reverse pulling the little slack back in the 4 cord weave. Simples see.
These are much stronger than I thought............
Before selling these I gave a one to a friend at work to try out as I don't have a dog.  At first he wasn't happy because he said "that cord don't look very strong". I explained about paracord, he didn't look very sure about it..
So the other day he told me (with a smile on his face) how he towed his classic VW camper out of his lockup using the dog lead , as that was all he had in the car. He put the handle around the tow bar of his car and looped the clip around the camper bumper and clipped it back on the lead. No damage to report!!
Re: Got Paracord?
Reply #511 on: May 19, 2010, 07:17:40 PM
Prime that again looks great.  I will have to go with something similar for my Sebbie I think.  :)
gb Offline Essexman
Re: Got Paracord?
Reply #512 on: May 19, 2010, 10:20:46 PM
And there's more..  I made this mini bell rope keyfob for a friend who's hobby is bellringing
And some other bits.....
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #513 on: May 19, 2010, 10:22:15 PM
nice work!
I
spam Offline John
  • Avatar removed by request
Re: Got Paracord?
Reply #514 on: May 19, 2010, 10:36:21 PM
+1  :tu:
@Essexman do you have any steel bearing for monkey fist lanyard?  :think:
gb Offline Essexman
Re: Got Paracord?
Reply #515 on: May 19, 2010, 10:58:06 PM
+1  :tu:
Ah bugger, I did a while ago!  Sold them all. My good wife found about 15 off 22mm SS bearing on eBay some time ago for a bargin price, but the seller has gone now  :(
BBuuuttttt there are other items you can use,..... I have 22mm wooden balls (no rude jokes please) again from eBay  and a nice collection on mouse balls ( I said NO rude jokes!) given to me by work  :D
Feel free to PM me if there's anything I can do to help.
Off to bed now, I'll catch up tomorrow.
spam Offline John
Re: Got Paracord?
Reply #516 on: May 19, 2010, 11:16:52 PM
I could trade you some bearings  ;) I'll check the size and report in the morning  :salute:
[edit] Ok checked they're 21mm and weigh 1.1 oz  :salute:
« Last Edit: May 19, 2010, 11:32:09 PM by John »
us Offline Stormdrane
  • Be Prepared
Re: Got Paracord?
Reply #517 on: May 20, 2010, 04:08:05 PM
A series of Chinese crown knots, tied with paracord...
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #518 on: May 20, 2010, 06:48:46 PM
ooh i like that  :tu:
I
ni-ulster Offline cerbera147
Re: Got Paracord?
Reply #519 on: May 20, 2010, 06:58:15 PM
I had to cut the other lanyard I made for my Insingo off because I didn't like the way the skull bead was rubbing against the blue annodized back spacer. I went with a round sinnet lanyard with a completion stitch this time.
That looks great  :tu:
I would like to give it a go; the actual weave I should be ok with but will struggle with the completion stitch  :-\
Are there any simple instructions for that? :D
Re: Got Paracord?
Reply #520 on: May 20, 2010, 08:15:07 PM
Great work Essexman.  :)
us Offline prime77
Re: Got Paracord?
Reply #521 on: May 21, 2010, 06:35:59 AM
Quote
That looks great  Thumbs up!
I would like to give it a go; the actual weave I should be ok with but will struggle with the completion stitch  Undecided
Are there any simple instructions for that? Grin
I figured it out by trial and error. What you need to do is make one more weave but keep it loose then pull each of the strands of cord under and trough.
Re: Got Paracord?
Reply #522 on: May 21, 2010, 07:29:59 AM
Damn there's some talented chap's on here :salute:
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #523 on: May 23, 2010, 01:24:37 PM
my first attempt at a snake weave lanyard actually turned out quite well :) pics to come when ive sealed the ends
I
gb Offline Essexman
Re: Got Paracord?
Reply #524 on: May 23, 2010, 06:25:29 PM
Try this here http://boondoggleman.com/prj_completion.htm
Back soon with more, all stuffed up with cold right now    :(
Re: Got Paracord?
Reply #525 on: May 23, 2010, 06:46:38 PM
Thank you kind sir  :salute: :tu:
Got another query :D  This may be simple but I can't see it  :-\
I am planning to use this through a lanyard hole on my knife. Do I start with the cord fed through the hole and a bit of excess?
Hope you get shot of that cold soon  :)
gb Offline Essexman
Re: Got Paracord?
Reply #526 on: May 25, 2010, 12:36:43 PM
No problem, glad to be of help.
I would say there's more than one way to attached a lanyard. If you can fit two cords through the hole than make a lanyard with enough spare length to fed through as shown here - http://www.knivesandlanyards.com/tutorial_on_stringing_your_lanya.htm
Otherwise you have to build/make the lanyard on the knife. Therefore start with one cord through the hole leaving a bit before you start knitting.
Cheers for the well wishes, cold is now an Respiratory tract infection, great fun. It's going, but slowley.
gb Offline Essexman
Re: Got Paracord?
Reply #527 on: May 25, 2010, 12:44:34 PM
A couple more from me...
First a celtic cross I made for my Mum.
and a bracelet for a football fan friend, he tells me that there's something going on soon with all the worlds teams playing each other?
Come on England !
us Offline yud
  • Still has a SOGgy feeling
Re: Got Paracord?
Reply #528 on: May 25, 2010, 08:09:25 PM
wow  :o :D
Re: Got Paracord?
Reply #529 on: May 25, 2010, 09:41:40 PM
Come on England !
Or Denmark..   :D :D
Great paracording..  8)
gb Offline Essexman
Re: Got Paracord?
Reply #530 on: May 25, 2010, 09:44:06 PM
Come on England !
Or Denmark..   :D :D
I'm sure the guy at work is English not Danish  ::)  I'll ask him tomorrow  :D
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #531 on: May 25, 2010, 09:45:23 PM
ive got paracord and dunno what to make, any ideas?
I
Re: Got Paracord?
Reply #532 on: May 25, 2010, 09:48:02 PM
Monkeyfist or a bracelet..  :)
us Offline yud
Re: Got Paracord?
Reply #533 on: May 25, 2010, 09:52:19 PM
Monkeyfist :tu: :D
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #534 on: May 25, 2010, 09:54:32 PM
nah i dont have any ball bearings :/ might try another lanyard :)
I
us Offline yud
Re: Got Paracord?
Reply #535 on: May 25, 2010, 09:57:39 PM
I used a marble in mine :pok:
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #536 on: May 25, 2010, 10:07:47 PM
err i have a skittle?  :rofl:
how do i do the circular weave lanyards?  :cheers:
I
spam Offline John
Re: Got Paracord?
Reply #537 on: May 25, 2010, 10:10:00 PM
Is there any machinery at work?  ;)  >:D
gb Offline ryan1835
  • buh
Re: Got Paracord?
Reply #538 on: May 25, 2010, 10:11:52 PM
hmm... i know where a bearing puller is, and im in the wrong bit of the company to get to go near the pretty machines probably best...
I
Re: Got Paracord?
Reply #539 on: May 25, 2010, 10:57:42 PM
You can make a monkey's fist without anything inside easy enough.
But I'd recommend bracelets as they're great things to learn with :)
