Those are great Spoonrobot. I like the "standard" set up for comparing all the lights. That Surefire MN16 lamp should help in an exploring emergency.
Hey Spoonrobot, I'm a little bored tonight and thinking of doing some outdoor beamshots like yours. I have a camera that can be put on different settings. What settings do you use to get some good shots?
Short answer: Fiddle with the settings until the picture looks just like real life. SmileyLong answer: It really depends on the Camera. For the above shots I used a Nikon FinePix Z5 set on night mode.Night mode automatically holds the shutter open long enough to take clear shots of distance beams but this mode is not something universally found on point/click cameras and only really serves to compare beamshots under the exact same conditions. Certain cameras also tend to wash out incandescent lights to pure white and LEDs to blue when actual tints are different to the eye. Try out the night mode on your camera first and if it washes out the beam or makes it look like a poor representation of the real light use the method below.Now, what I used to do before getting this camera was set the options to Manual and then adjust the Exposure setting up or down until it looked right to my eyes. Most beam shots I took this way were done at -2/3rds exposure but the settings vary by camera. My last digi-cam had settings from -5.0 to +5.0, this cam only does thirds to -2 and +2. By using the manual mode you get a slightly more realistic beamshot but this really only matters if photographing ceiling bounce shots to compare output or photographing floodier beams at a distance. When photographing certain LEDs I will also use this method in conjunction with white balance adjust to get the most accurate representation of tint.If you really want the best representation of the beam use the manual+exposure, but if you just want some comparison pics try the night mode on your camera.You probably already know this but long exposure times make it almost a requirement to use a timer and a tripod for the pictures.Good luck! Post them when you're done!
What's the ball thing at base of tree?
Some of the lower output lights have a washed out look but are still passable.
That's one I haven't seen. It looks pretty neat--like Fenix meets VB-16.How are you liking that one? What is the UI like?
I generally only use the highest/lowest and 2nd lowest levels, the others are a typically a waste for me but this light is one of the few multi-mode lights that always activates on high so it was close to my ideal light. The clickies under the red switches have a very positive tactile and audible feedback.The low is very low and is good for preserving night vision but I do wish there was slightly more spread between the levels and less levels overall.
