New SOG
J-sews · 29 · 9470
New SOG
on: November 09, 2006, 03:27:07 AM
Check out the new Paladin PowerPlay 540, made by SOG.
It looks to be based on a PowerLock chassis, with some enhancements. So far I'm noticing a radical new plier head, with wire stripper notches. And it looks like a different blade lock release mechanism. Also, the handles look different, with some strange cutouts and notches?
Anybody know more about it?
Re: New SOG
Reply #1 on: November 09, 2006, 11:31:58 AM
No, but I will contact SOG and see if they can provide more info, pics etc....
us Offline parnass
  • 4x4 since '74
Re: New SOG
Reply #2 on: November 10, 2006, 02:37:20 AM
The PT-540 is now sold at http://amazon.com
I like how the sharp gear teeth in the Paladin PT series tools are shielded while the handles are closed so they don't pose a hazard.  Hope the next generation of SOG-branded multitools will incorporate the same improvement.
Retired engineer, author.
Re: New SOG
Reply #3 on: November 10, 2006, 03:11:46 AM
Ouch! They are a tad bit expensive, aren't they?
Re: New SOG
Reply #4 on: November 10, 2006, 03:23:18 AM
SOG tools have always unfortunetaly occupied the top end of the multitool price level- at least until Leatherman came out with titanium and 154cm.
Re: New SOG
Reply #5 on: November 10, 2006, 03:48:01 AM
I like the looks of this new tool. It's all radical and Robo Coppy looking. Something that Arnold the Terminator might EDC for maintaining his x-ray laser cyclatron rifle. And if I know SOG, the thing works as good as it looks. I want one.
Trying......to.........resist.......Can't........hold out.....much.......longer.
Re: New SOG
Reply #6 on: November 10, 2006, 03:52:15 AM
I thought Terminators used Gerbers?
Re: New SOG
Reply #7 on: November 10, 2006, 04:21:31 AM
A common misconception. Some rouge T800 unit actually only did a product endorsement deal with Gerber in order to get some beer money. SkyNet regs specify only genuine SOG's as standard issue to Terminator units.
Re: New SOG
Reply #8 on: November 10, 2006, 12:10:35 PM
I always wondered about that with the Terminators- all those exposed wires... why waste time shooting them when you could probably just run up to them with a good set of wire cutters?   I'll bet the SOG compound leverage would give them a critical fault in Drive C pretty quick.  They all you would have to do is click "no" when the "Do you want to continue running Death.exe?" and you could move on to the next one!
Offline colubrid
Re: New SOG
Reply #9 on: November 10, 2006, 03:37:35 PM
That thing is HOT. Wooo weeee! O0
Re: New SOG
Reply #10 on: November 11, 2006, 12:56:55 AM
Right on bro', now THAT'S what I'm talkin' about!  O0
Re: New SOG
Reply #11 on: November 11, 2006, 12:58:41 AM
The Paladin website has a list of the included blades:
http://www.paladin-tools.com/view_tool.php?id=490
Q: What the heck is a spudger?
Re: New SOG
Reply #12 on: November 11, 2006, 01:20:32 AM
Quote
I dunno, but it sounds kinda dirty...
Offline I'm Still Bison
Re: New SOG
Reply #13 on: November 11, 2006, 04:15:52 AM
Quote
Hey..Is Inky lurking here too?!!
I
Offline damota
Re: New SOG
Reply #14 on: November 12, 2006, 09:40:14 PM
It is their name for the extension to the hook blade, it apparently can be used to rake the muck out of a wall socket before replacing the plate, like you would normally do with a fine screw driver.
Dave
« Last Edit: November 12, 2006, 09:41:58 PM by damota »
Re: New SOG
Reply #15 on: November 12, 2006, 10:32:43 PM
I am glad that in a group full of tool guys, at least one guy knows what it is!
Offline damota
Re: New SOG
Reply #16 on: November 12, 2006, 10:57:08 PM
The only reason I knew that was because through reading the use of the tools on the Paladin site I learned a usefull use for the hook on my Cybertool. A parcel carrier it said on the Vic sheet I got, hooking wires makes far more sense.  :-[
Dave
Re: New SOG
Reply #17 on: November 13, 2006, 12:53:08 AM
Hey, I just realized I've spudged before, and never even knew it!
us Offline Fred
  • I'm the one they call Dr FeelGood
Re: New SOG
Reply #18 on: November 13, 2006, 04:51:36 PM
Me too.in fact, I was spudging all over the place last summer when we re-did the basement
Yabba dabba doo!
Re: New SOG
Reply #19 on: November 14, 2006, 02:22:12 AM
Eeww, I think this thread is going downhill in a hurry.
Okay, back on track:
I'm looking real close at these pictures, and a couple things are buggin' me. What is that hex-looking cut-out for partway down the handles? It looks to be a double thickness of metal there for some reason?
And what is the little doo-dad hanging just below the plier handle pivots?
Re: New SOG
Reply #20 on: November 14, 2006, 02:30:36 AM
Interesting observations....
Offline joebw
Re: New SOG
Reply #21 on: November 14, 2006, 04:15:31 PM
From Wikipedia
"The term spudger describes a general class of tool used for poking, adjusting, or adjusting small wires or components, generally in the electronics or telecommunications industries.
The most common spudger is a black or yellow nylon stick, with a bent metal hook at one end. Various versions have blunt, sharpened, or insulated hooks. The hook can be used for pulling bridge clips from 66 blocks, manipulating wires in a crowded wire wrap block, or setting DIP switches. The body of a plastic spudger is usually contoured to offer a better grip."
Cheers - Joe
us Offline eodtech
Re: New SOG
Reply #22 on: November 16, 2006, 04:54:57 PM
Quote
Quote
If your a humanoid it a dingle berry ,  a Treky it's a " cling on "
I'm calling SOG today , I have a few questions myself.
Why do I carry a 45 ?
Offline damota
Re: New SOG
Reply #23 on: November 17, 2006, 12:52:41 AM
From Wikipedia
Cheers - Joe
I think the significant is that a spodger is normally made out of plastic, nylon or anything that is non conductive. That is why I said it is their name for the tool I know I would not like to use that anywhere there was live voltage no mater what current was involved, for instance try and use that to get a wire cover that you have just striped from a wire out from under a mother board I think you will soon see that all computers run off steam  ;) as you catch a couple of solder beads under the board. I think I will stick to a made for the job tool. they cost next to nothing.  :-\
Re: New SOG
Reply #24 on: November 17, 2006, 02:13:29 AM
I kinda thought a metal implement would be a bad thing when working with electricity, but then I could electrocute myself looking at a painting of lightining...
us Offline Fred
Re: New SOG
Reply #25 on: November 20, 2006, 03:09:07 AM
wow, that's spooky  :D :D
Yabba dabba doo!
Re: New SOG
Reply #26 on: November 20, 2006, 03:14:51 AM
Seriously- I built a model car as a kid, installed a small motor, as per the instructions, and when I put batteries in it (didn't even turn it on!) they started to smoke!
Electricity and I don't see eye to eye.
Re: New SOG
Reply #27 on: November 21, 2006, 03:32:02 AM
Okay "Sparky." (Or maybe it should be "Smokey?")
Anyhow, thanks for getting all the info on the new SOG/Paladin tool:  http://forum.multitool.org/index.php/topic,371.0.html
Re: New SOG
Reply #28 on: November 21, 2006, 03:36:45 AM
 O0
No problem.  The rest will show up sooner or later...
