My latest flashlight is a Streamlight ProTac 90. It is shown next to 2 Energizer right angle lights. All of them can be powered by a single AA battery, but the ProTac 90 can be powered with either an AA, AAA, or CR123 battery.(Image removed from quote.)
I picket up the middle Energizer for my father-in-law. An excellent light for those who don't require multiple modes etc.
A NEBO PaL +.3 functions on tap.1. 400 lumen flashlight with strobe and variable power from 40 lumen up to 400 lumen. Press the button once to power up the flashlight. Double tap it to get the strobe. Hold the button down and the light will dim and get brighter...with a blink at both the lowest and highest end. Simply release the button at the desired light level.2. A built in 3 inch knife that is also easily removed for those countries where having a liner locked blade is undesirable.3. A power bank.The flashlight uses rechargeable batteries. When plugged in, the flashlight will flash red to indicate charging at the charging port. When the red led is constant, then you are fully charged. To use the flashlight as a charging device, insert the USB cable in the flashlight, and the other end into the device you need to re-charge. When using it for this purpose, the tail red indicator light will change to blue.DSCN0831A by Chako, on FlickrThe blade is of good size and also features both a plain and serrated edge.DSCN0837A by Chako, on FlickrThe end cap pulls off and gives you access to the charging port and the USB port to use the device as an emergency charging device.DSCN0838A by Chako, on Flickr
The light hat is pretty cool MadP. Nice lights Sos and marko. Been running a Photon X on me keyring for a good long while. I almost bought the many different keychain lights that came out since but nothing tempted me beyond . Accidental on is never a good thing for a light that will mingle with keys and car fobs. I hope yours will remain off and only turn on when activated.
Two recent AAAs. One is a very hot-rodded ToolVn Ti and the other is a Prometheus Beta Ti.(Image removed from quote.)
Mine is SolarForce L2T.(Image removed from quote.)(Image removed from quote.)
NEBO Poplight and Angle light AA.
I just got a used Oveready BOSS.
Never heard of it before but wow,whata flashlight Congrats Pictures and thoughts once you have had time to play with it a bit
Nice little light pipedreams Do you use the UV mode often?
