One-hand on a Juice
Offline ral2002
  • New User
Re: One-hand on a Juice
Reply #30 on: January 28, 2008, 04:51:16 PM
I have been working on similar modifications.  I have taken a Juice apart by grinding out the rivets.  I was not able to get the rivets out without damaging the aluminium scales.  One of the interesting things that I learned was how the tools are constructed.  The pliers part is built into a single piece of steel that forms a U then each of the outside tools is built into a L shaped bracket the attaches to the U.  So cutting away the L shape will not weaken the pillars.  I attempted to use brass rod for the pivot points, but peened the one too hard and now the screwdrivers are difficult to get out.  Next step is to figure out a thumb stud and pocket clip.  I will also need to determine if the brass is strong enough for the pliers.  I should also note that one of my goals was to eliminate the corkscrew layer.  The rivet for the corkscrew only attaches to the outside layer and does not go through to the pliers layer.
* img_0719 (1)c.JPG (Filesize: 50.32 KB)
* IMG_0720c.JPG (Filesize: 40.92 KB)
* img_0721c.JPG (Filesize: 35.08 KB)
us Offline hawkchucker
  • I miss Benner
Reply #31 on: January 28, 2008, 07:58:15 PM
Excellent photos! And it kinda looks nike Naked!
By the way welcome, and great first post.
S
Reply #32 on: January 28, 2008, 11:14:14 PM
That looks awesome without the scales!! :o
Reply #33 on: January 29, 2008, 01:45:17 AM
Excellent point ral, I see now what you mean. Very good observation, and kudos on the mod job! 8)
us Offline NeitherExtreme
  • Marsh-wiggle
Reply #34 on: February 05, 2008, 12:42:18 AM
Awesome first post! I've thought about a "scaleless" Juice for a long time... Seing that picture just make me want it more. Very cool.
  • I miss Benner
Reply #35 on: February 26, 2008, 10:10:31 PM
OK 3 bits down and still not a scratch ont he blade. Def sent me a great little stud that screams Juice.
Any sug on how to get a hole in the blade without having to retemper?
S
Reply #36 on: February 27, 2008, 12:41:59 AM
Laser beam? :D
Seriously, I think I'd do it on a drill press with LOTS of oil... but then that may be why I'm not a professional! :D
I'm glad it got there safe and sound! :D
There are none so blind as those who will not see.
  • I miss Benner
Reply #37 on: February 27, 2008, 01:13:58 AM
I wont be giving up on this. I have allready milled the scale and I got to get the hole done right. I really got to go to the store and buy a crapload of cutting fluid and bits.
S
Reply #38 on: February 27, 2008, 01:58:41 AM
Hawk, the most important thing will be to use a drill press, not a hand drill. You want the hole to be straight and round, not all wallered out like a hand drill is likely to do.
Also clamp the blade down onto a sacrificial piece of wood so it can't move around. Use the slowest possible RPM's, and use some sort of light oil.
Reply #39 on: February 27, 2008, 01:59:41 AM
What?  I was right?
How the heck did that happen? :P
Reply #40 on: February 27, 2008, 02:06:22 AM
What?  I was right?
I was just trying to give you some positive reinforcement after that devastating email you got earlier today! ::) :D
Reply #41 on: February 27, 2008, 02:09:25 AM
That's ok, I already put a band aid over my emotional scar! :P
Hope that Mickey and Goofy are treating you well?
Reply #42 on: February 27, 2008, 02:14:16 AM
......Hope that Mickey and Goofy are treating you well?
Do you realize there is not a single knife or tool store in the entire Magic Kingdom?! >:( >:(
Reply #43 on: February 27, 2008, 02:28:26 AM
It's magic so nothing ever breaks down!
Those of us who live in the real world need more than fairy dust to be prepared! :D
us Offline prime77
Reply #44 on: February 27, 2008, 04:47:35 AM
After the trouble I had just drilling through a Charge pocket clip I can imagine how difficult it will be to go through the blade. Best of luck to you hawkchucker.
Offline scibeer
Reply #45 on: March 06, 2008, 05:08:19 AM
I just started reading this thread and wondered if anyone has tried solid carbide bits.
They are the only way to go if you actually want to drill hardened stainless and not wear a hole through it.
They are really expensive but you can get a pretty decent discount on them if you buy lots.
Solid carbide is super brittle and they shatter easily so you can ONLY use them on a drill press.
I think the spade tip ones are best for drilling a pilot hole and then the fluted ones can be used to open it up.
You get the most bang for the buck that way.   I can usually get a couple pilots out of the first bit and several uses out of the fluted ones if I'm careful.
I'll pick up a juice and see if I can get through the blade.
  • I miss Benner
Reply #46 on: March 06, 2008, 11:38:23 AM
A link would be great!!! I am having no luck what so ever.
S
Reply #47 on: March 07, 2008, 02:52:06 AM
A link to carbide drill bits? Send me a PM with the size you need and I'll hook you up.
Bob
Offline Tom Munch
Reply #48 on: March 14, 2008, 04:48:43 PM
I found that I can almost one hand the S2 as is if I lube up the pivot sufficiently.  It's almost good enough.
I'm really wanting the Juice to be more usable.  I love the Skeletool as you all know, but I find myself wanting a Juice-sized MT with one-handedness & locking implements in a very bad way.  LM folks, is this something you've considered?
Reply #49 on: March 18, 2008, 12:25:05 PM
Any more luck with this Hawk?
  • I miss Benner
Reply #50 on: April 02, 2008, 01:03:00 AM
Well i just answed a PM from Roadie. I havent had any time to play with this as of late and really have had no time at all. Work is killing me and I really just pop in for a couple seconds every few days.
I will be getting back to this soon.
S
Reply #51 on: April 02, 2008, 01:10:29 AM
Take it easy John- you can't let work become a way of life!   >:D
  • I miss Benner
Reply #52 on: April 02, 2008, 01:21:24 AM
See  someone loves me!!!
My wife just wants the cash.
S
Reply #53 on: April 02, 2008, 01:32:10 AM
Dead husbands are worth more and take up less space than life ones...
Reply #54 on: April 02, 2008, 02:41:02 AM
My wife will want a t-shirt with that on it!
Reply #55 on: April 02, 2008, 03:49:06 AM
A black one so she can wear it at your funeral?   :pok:
  • I miss Benner
Reply #56 on: April 02, 2008, 10:32:50 PM
Hey at least yours dont remind you on a daily basis that You are worth more dead than alive.
OK now she wants me to change the lightbulb on the stairs. But hey she also said she would hold the ladder.
S
Reply #57 on: April 03, 2008, 12:21:49 AM
As long as she doesn't up-end a running lawnmower under you when you do, it should be ok! :D
Reply #58 on: April 03, 2008, 02:22:04 AM
He's starting to get suspicious about all those Life Insurance forms she had him sign last month.  :ahhh
  • I miss Benner
Reply #59 on: April 03, 2008, 03:22:33 AM
Actually its funny you mention that. I just did reup mine! :ahhh :ahhh
S
Total Receipts: $344.11
PayPal Fees: $18.85
Net Balance: $325.26
Above Goal: $25.26
108%
