Am I right in thinking it looks about the size of a SOG PPP or a PSTII?If you can, a thickness comparison between the Charge and Rebar would be awesome.
Quote from: Max Archer on January 18, 2012, 04:39:49 AMAm I right in thinking it looks about the size of a SOG PPP or a PSTII?If you can, a thickness comparison between the Charge and Rebar would be awesome.Rebar thickness is about the same as a Charge. (which means it is slightly thicker than the PPP or the PST II of course)You could also think of its thickness as being comparable to a Leatherman Fuse, thinner than a Leatherman Blast.
Quote from: J-sews on January 18, 2012, 05:40:43 AMQuote from: Max Archer on January 18, 2012, 04:39:49 AMAm I right in thinking it looks about the size of a SOG PPP or a PSTII?If you can, a thickness comparison between the Charge and Rebar would be awesome.Rebar thickness is about the same as a Charge. (which means it is slightly thicker than the PPP or the PST II of course)You could also think of its thickness as being comparable to a Leatherman Fuse, thinner than a Leatherman Blast.Aw, that's too bad, I was really hoping for a slimmer tool that would carry well in the pocket. I guess I'll just have to get one and see.
So it looks like the Rebar is to the Supertool 300 as the Pulse was the small version of the Supertool 200? I have a two Pulse models and an original Supertool but have never had a Supertool 200 to compare the Pulse to. The Rebar looks like a better size for me...even though I wear a size 17 ring.John
VERY NICE!! I like the spring on the plier handle pivots. Little Victorinox intuition being borrowed there eh? The wire crimper was not in the prelim photos, glad to see it on the prototype. I think the retention of the small flat head is awesome, I don't know about the rest of you but that is my go-to poke, prod, and scrape tool. The awl will be good for that too, but I like to keep those sharp.I notice the fine grip section of the pliers has been cut similar to the Wingman, the Blast has finer teeth. Does it look like they are as good as the blast? Also, what is on the reverse of the file?
