Syph007 · 6035 · 1299618
Reply #4680 on: June 19, 2017, 11:49:11 PM
Oh sweet!
au Offline Huntsman
Reply #4681 on: June 20, 2017, 12:57:41 AM
Hmmm -
Can the Tormach really machine that finely? I know if Syph is planning to do this - then he will have checked it out and it can!  :)  - Incredible   :o
I guess the drill/machine head goes around the outside (and inside) of each of the tweezers and leaves the full block (frame) intact and fully bolted down at the corners
These will look amazing - Can't wait to see them
- But it does seem like a big waste of Ti to me   :(
ca Offline Syph007
  • SAK Surgeon
Reply #4682 on: June 20, 2017, 01:06:27 AM
Hmmm -
That's a 2 inch by 4 inch piece of Ti.  About 15 dollars of Ti to make 14 tweezers.   The real cost is in broken endmills and I won't know that until I try.
The tormach has the resolution no problem.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
au Offline Huntsman
Reply #4683 on: June 20, 2017, 01:16:03 AM
Hey Syph - Thanks for coming back to us  :tu:
So I guess quite a lot of waste - But not a lot of cost and still only $1 a tweezer - That seems worth it!!  :tu:
And I guess quite a lot of milling time too.
Hope you don't get too many broken bits !!
I guess if you worked in a foundry all the left overs would go back in the furnace.
I worked in a precision castings foundry once - where we used the inverted lost wax method to make the castings - All the leftover frames/trees just went back in the furnace, for the next run !
Sorry to harp on - Recycling and waste is one of my obsessions  :-[
00 Offline WWW
Reply #4684 on: June 20, 2017, 02:48:31 AM
Do you think it is more viable, considering the surface finish and not having to do so much finishing on such tiny parts, to just mill it rather than waterjet cutting? Because of the sizes of mills you will have to use the first thing tht came to mind was the waterjet. But the finishing afterwards on such tiny parts, as I previously stated, made me think it would not be worth it. What are your thoughts?
BTW congrats, I'm glad that you're doing this for a living, I imagine it is really fun.
ca Offline Syph007
  • SAK Surgeon
Reply #4685 on: June 20, 2017, 03:32:25 AM
Waterjet finish is pretty rough ya and it also doesnt make perfectly perpendicular to the surface cuts.  Not ideal for very thin components.  Also I can work on a cutting strategy to keep supports in place on the outside while I cut the inside and tips, then cut the outsides last and leave little tabs.  Only the very inside part will need the 1/32 bit the rest will be cut with the 1/16.  I finished the Gcode so I can try it tomorrow.   :tu:
00 Offline WWW
Reply #4686 on: June 20, 2017, 02:24:17 PM
Good luck!!!  :tu:
ca Offline Syph007
  • SAK Surgeon
Reply #4687 on: June 20, 2017, 05:06:13 PM
First cuts went just fine... Now does it work?
Reply #4689 on: June 20, 2017, 05:24:29 PM
fr Offline m47mu74nt
Reply #4690 on: June 20, 2017, 05:42:21 PM
:popcorn:
+1 :popcorn:
:popcorn:
               :popcorn:
                             :popcorn:
Reply #4691 on: June 20, 2017, 06:31:34 PM
The suspense is killing me :ahhh :ahhh :ahhh
:popcorn:
Reply #4692 on: June 20, 2017, 06:38:34 PM
Me too!  :ahhh
 :popcorn:
Offline Psych
Reply #4693 on: June 21, 2017, 12:07:47 AM
Syph,
Seeing the springy nature of the tweezers you're now working on reminds me that quite a while back, you were making liner locks for some 93mm mods you were doing at the time. Any chance that idea could translate to the 91mm mods you're doing?
us Offline MusicMen
  • 21 Badges for Eagle
Reply #4694 on: June 21, 2017, 03:12:35 AM
Well???
 :popcorn:
BUCK: X-Tract, 360
*=mod
si Offline lister
Reply #4695 on: June 21, 2017, 01:08:54 PM
So how long before you start making your sak-s completely from the ground up?  :D
« Last Edit: June 21, 2017, 01:11:58 PM by lister »
ca Offline Syph007
  • SAK Surgeon
Reply #4696 on: June 21, 2017, 01:29:02 PM
The leaves of the tweezers were too thin.  Machined fine though but I got a better idea on how to cut them and not need a tiny 1/32 bit.
si Offline lister
Reply #4698 on: June 21, 2017, 04:45:40 PM
 :ahhh
00 Offline WWW
Reply #4699 on: June 21, 2017, 07:19:58 PM
Does it involve a horizontal milling machine?
ca Offline Syph007
  • SAK Surgeon
Reply #4700 on: June 21, 2017, 07:50:52 PM
No.  I realized I could have machined the tweezers with the leaves far apart, and bend later. I didnt have to have them so close and use such a tiny bit.   :facepalm:
00 Offline WWW
Reply #4701 on: June 22, 2017, 03:22:29 AM
At least you realized that, it didn't even occured to me! My thought process was more in the lines that a horrizontal mill will have more support, you could cut a long groove (like an Al extrusion, think the side profile of the tweezers) and than just cut them off. Good solution you've found, I hope it works well.
ca Offline Syph007
  • SAK Surgeon
Reply #4702 on: June 23, 2017, 01:25:20 AM
Ive FINALLY come up with a way I like to hold all the scale tools people want.  Drawing it up now in CAD then I can post what Im thinking of trying.  The pen is still too thick to fit unless I can find an option for a thinner one, but regardless if this works I can fit ...
Toothpick
Tweezers
Small firesteel
Pin
Sewing needle and thread
That takes care of what most people would want, and there will be a small space left over to store whatever else could be jammed in there.
Ive been stuck forever trying to work out the mechanism.  I know I could machine a little drawer hollow that opened in the scale, but how would it lock into place to avoid accidentally opening, and it would also have to be simple so that machining time/cost wasnt too much more and no extra parts like more screws and tapping would be needed.
I did have to go with much thicker Ti for the backscale 0.155" instead of the 0.100" I used now, but that at least this will provide a way to offer people what they want.  It would still be slightly thinner than a stock SAK with plastic scales though (0.070" thinner) since it still wont have the outer liners.  So still an ok compromise I think for those that would want this.
My breakthrough in mentally working on this was realizing how I could machine the drawer to have a built in retension spring to snap it home and become a solid part of the scale when not needed.  A small nail nick would be exposed either on top on inside to pop it open.  It would be part of the back scale and open upwards like a normal tool, but the hinge point would be towards the inside not where the normal tools pivot.
us Offline Monrogue
  • Wooooo!
Reply #4703 on: June 23, 2017, 01:52:02 AM
Oh that sounds interesting Syph :tu:
Proud SAKMC member :)
K-Tibbs
Reply #4704 on: June 23, 2017, 04:02:05 AM
 :o What Mons said :ahhh :ahhh :ahhh :like:
Reply #4705 on: June 23, 2017, 07:07:32 PM
 :worthless:
:pommel:
si Offline lister
Reply #4706 on: June 23, 2017, 07:11:28 PM
ca Offline Syph007
  • SAK Surgeon
Reply #4707 on: June 24, 2017, 12:31:49 AM
:worthless:
:pommel:
+1
So far Ive only cut out the thicker backscale.  Im arranging components on top of that to try to decide the shape to cut.
I do have pics of today's build SAK though.  :D
au Offline Huntsman
Reply #4708 on: June 24, 2017, 04:22:09 AM
Wow - A Master Ranger ??? - With Pruner and Hex wrench :o
And settles the CS vs Ph debate  :D
Is that a Ti corkscrew or is it just a trick of the light?
Amazing stuff as always my friend!!
« Last Edit: June 24, 2017, 04:23:13 AM by Huntsman »
Reply #4709 on: June 24, 2017, 12:40:31 PM
Great toolset on that one :o :like:
I love the cut out in the scales as well :dd: :like:
