Forgive me.I posted in the wrong thread
Quote from: Threeme2189 on January 29, 2012, 07:50:12 PMForgive me.I posted in the wrong thread Sorry, can't do it. This has been one infraction too many, and I'm afraid we have to ban you now. Def
As you know, I have done a bit of kayaking in my time. What I am going to say is not the Be All End All of kayaking, but these are my experiences.First off, don't buy a Pelican. They are decent enough "f*cking around boats" but don't expect to use it for much more than paddling around in a decent sized pond or small lake. You won't get far in one, and you'll waste a lot of energy in one trying to get there.Without going into too much detail, what you need to do is identify what kind of kayaking you want to do and buy an appropriate boat. From what you were suggesting, it seems to me that you are likely to do mostly what I do- lakes and slow rivers. Serious rapids will require a dedicated whitewater boat, and ocean traveling will require a sea kayak. It all boils down to something called "tracking." A longer boat tends to track better because it resists turning from one side to the other when you paddle. If you want to travel any distance, this is imperative since that side to side motion wastes energy. I would suggest a 12-16 foot boat for most travel trips. These are referred to as Light Touring or Recreational boats and will handle usually about 350-450 pounds so you are good for bringing along some camping supplies. Look for a well defined keel which coaxes the boat to stay straight. These boats aren't as maneuverable as a whitewater boat, but are much more efficient for traveling long distance.Pelican boats have a wide flat bottom for some stability, to help beginners get used to it, but you will find that you quickly outgrow it. Anyone interested in kayaking will sell these off in a year or so, or give up kayaking because these boats are remarkably ineffective.There's a lot to it, but I'll be happy to answer any questions you have. In short, what you should be looking for is a rotomoulded plastic boat at 12-16 feet. At that size a rudder is handy but not necessary. and not having a rudder can save you up to $200 on a new boat. You also want to make sure that there are good, large hatches. The Pelican ones are very small, barely capable of holding anything. Lastly, look on Craigslist or local kayak websites for a second hand boat. $500 is a bit unreasonable for a new boat as you are going to spend close to that on outfitting alone- paddles are around $100 (for a decent set- look for carbon fiber rather than aluminum), a good paddling life vest (regular boating vests are bad) will be between $50-100, a throw bag, a rack for your car or truck and so on.These are the things you need to start- then once you've started there are lots of goodies you can add on as you want them.Check out the Aquafusion Liberty:http://www.aquafusion.com/our_kayaks.htmIt's a bit above your price range, but it's a good boat and should handle almost anything you want to put it through.Def
