Login
Register
Menu
Home
Help
Forum
Tool Talk
Leatherman Tools
TTi rescue hook
TTi rescue hook
8thsinner
14 ·
2251
« previous
next »
Print
Pages:
1
Go Down
8thsinner
Newbie
26
TTi rescue hook
on:
February 09, 2012, 04:53:20 AM
I am hoping someone out there has found a nice easy way to sharpen the rescue hook on the TTi model. I actually use this a hell of a lot to skin and recycle leather from old sofas and I doubt right now it would even cut paper. Strops and mini honing steel is no longer an option.
Also any jigs or what ever to make the serrated blade sharpening go easier would be nice but I am sure with some fiddling I can come up with something for this.
Doing the right thing is bleeding for the cause
bdjeep
Newbie
41
Re: TTi rescue hook
Reply #1 on:
February 09, 2012, 05:21:36 PM
Something like the Spyderco Sharpmaker is supposed to work well on the serrations. I was wondering if the triangular stones would reach into the groove for the rescue cutter and sharpen it. I have also seen small portable sharpeners that consist of a small diameter rod covered in diamond grit. Those might work on the little groove. You could also get some very fine grit sandpaper such as 600 or 1000 grit and wrap it around a small rod or nail or stiff wire and work that down into the groove.
Mercury
Admin Team
Absolutely No Life Club
8,922
Wearer of the Cloak of Band-aye-eed.
Re: TTi rescue hook
Reply #2 on:
February 09, 2012, 05:55:37 PM
I have a spyderco sharpmaker and can testify to it's awesome ability to sharpen serrated knives, but it cannot fit in the gut hook on a TTi. I would try a Smith's diamond rod.
Sean
Merit Badges
Threeme2189
No Life Club
2,021
When in doubt, use a bigger hammer.
Re: TTi rescue hook
Reply #3 on:
February 09, 2012, 07:09:35 PM
Try a shoelace with some abrasive compound smeared on it.
I don't know if it works, but it might be worth a shot.
8thsinner
Newbie
26
Re: TTi rescue hook
Reply #4 on:
February 09, 2012, 08:50:35 PM
The shoe lace would make a great buffer I think, but a diamond rod with high grit paper sounds like the best way to go to bring the edge back up.
bdjeep
Newbie
41
Re: TTi rescue hook
Reply #5 on:
February 09, 2012, 09:23:21 PM
Quote from: Mercury on February 09, 2012, 05:55:37 PM
I searched and found this one. I think it would work, if it is small enough in diameter.
http://smithsedge.com/products/product.asp?id=25&cid=10
genevabuck
No Life Club
1,074
Re: TTi rescue hook
Reply #6 on:
February 09, 2012, 09:33:20 PM
leather shoelace or cord.
tattoosteve99
6,316
TTi rescue hook
Reply #7 on:
February 10, 2012, 05:40:23 AM
This one works extremely well.
http://www.woodworkingshop.com/product/wk24730/
One suggestion though. On rounded or serrated tools. Sharpen in one direction only, toward the sharp edge. Oh and the reason I like this one is I can sharpen more than one size.
Merit Badges
Sparky415
Zombie Apprentice
12,996
Re: TTi rescue hook
Reply #8 on:
February 10, 2012, 11:02:52 AM
If you have a dremel it might be worth trying a small polishing mop and polishing compound
8thsinner
Newbie
26
Re: TTi rescue hook
Reply #9 on:
February 10, 2012, 01:42:24 PM
I do have a dremel actually, but never thought to use a power tool for sharpening purposes, least not for a tool of value anyway. Thanks. I will try it later.
Sparky415
Zombie Apprentice
12,996
Re: TTi rescue hook
Reply #10 on:
February 10, 2012, 05:39:54 PM
Obviously protect your eyes
and don't let the edge get too hot
I have used my buffing wheel on serrated blades before with good results so the dremal should work for you
Styerman
No Life Club
3,572
Re: TTi rescue hook
Reply #11 on:
February 10, 2012, 06:05:09 PM
I use a leather lace loaded with green buffing compound , if stuff is really tragic , I have a couple of small round diamond files ( never needed on my stuff , but others are more abusive ) .
Be carefull with the Dremel 400 series stainless can draw ( lose hardness) in the 400 degrees F. range .
Chris
8thsinner
Newbie
26
Re: TTi rescue hook
Reply #12 on:
February 10, 2012, 06:11:18 PM
Thanks for the all the advice btw. Won't have time later now but hey crap happens right...
RayzBladz
Jr. Member
83
Re: TTi rescue hook
Reply #13 on:
February 11, 2012, 01:27:19 PM
Benchmade makes a slick little 12 piece tool kit (#985995F) that has phillips, slotted, allen, and torx drivers with a sharpener that fits in there perfectly.
Print
Pages:
1
Go Up
Forum
Tool Talk
Leatherman Tools
TTi rescue hook
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$158.99
PayPal Fees:
$9.20
Net Balance:
$149.79
Below Goal:
$150.21
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
