Heres a cheap traveler for you to try and let us know... http://www.ebay.com/itm/Wenger-Traveler-Swiss-Army-knife-in-black-/290687930481?pt=Collectible_Knives&hash=item43ae59d071
Quote from: Syph007 on March 26, 2012, 06:49:09 PMHeres a cheap traveler for you to try and let us know... http://www.ebay.com/itm/Wenger-Traveler-Swiss-Army-knife-in-black-/290687930481?pt=Collectible_Knives&hash=item43ae59d071I pass the buck to you. Go for it.
2.5mm holes from memory, couldn't see why it wouldnt work, maybe the nail knicks might be an issue.Whats really interesting is that the wenger aluminium spacers outer two blade holes line up with 84mm victorinox, the two inner backlayer holes also can line up but cant get all 4 holes to line up at the same time. Shame as then it would almost be a case of swapping complete layers
Quote from: Santos on March 27, 2012, 03:07:04 AM2.5mm holes from memory, couldn't see why it wouldnt work, maybe the nail knicks might be an issue.Whats really interesting is that the wenger aluminium spacers outer two blade holes line up with 84mm victorinox, the two inner backlayer holes also can line up but cant get all 4 holes to line up at the same time. Shame as then it would almost be a case of swapping complete layersNo, they are not, wenger uses bigger pins.
Quote from: enki_ck on March 27, 2012, 03:12:01 AMQuote from: Santos on March 27, 2012, 03:07:04 AM2.5mm holes from memory, couldn't see why it wouldnt work, maybe the nail knicks might be an issue.Whats really interesting is that the wenger aluminium spacers outer two blade holes line up with 84mm victorinox, the two inner backlayer holes also can line up but cant get all 4 holes to line up at the same time. Shame as then it would almost be a case of swapping complete layersNo, they are not, wenger uses bigger pins.Wenger 2.5mm Holes Victorinox (84mm) 2.2mm holes The holes line up in the liners (called them spacers earlier... couldnt think of the word liner )... not the same diameter.. but the two outer holes line up OR the two inner holes for the backlayer.. but the backlayer is offset so you can't line up all 4 holes at oncewooohooo my english is coming back to me Should of just taken a photo
Do the back springs differ?
I have never taken a Wenger apart. Do the rivets work the same as Vics? I am just going to have to jump in.
