4 and 5? I deny any existence of either Matrix 2 or 3! The Matrix was a cool movie, too bad they never made any sequels.
However, I was of the opinion that Neo dies at the end of Revolutions. The way it ended seemed pretty conclusive that he does.
Quote from: Heinz Doofenshmirtz on April 08, 2012, 11:53:25 PMHowever, I was of the opinion that Neo dies at the end of Revolutions. The way it ended seemed pretty conclusive that he does.Years ago I had heard that if the movies had ever gone on, that the brothers had intended to have Neo's physical body die but that his mind would be written into a program (like the Oracle, Seraph, etc), and then he would become an Android that would strive to bridge the divide between the humans and machines as they worked together to clear the sky.
That feels a bit too much 'lived happily ever after' for me.
When the machines carry him off he is still glowing in light. Also the oracle says she believes he will be back "someday".
Yeah I know it's weird but this movie inspired me to do deep thinking on other possibilities of life and existence.
I believe the brothers can handle that
The machines carrying away Neo definitely gave off an “carrying Arthur away to Avalon vibe”. In versions of the ballad including Avalon, I seem to remember Arthur is supposed to return when the need for him is the greatest. (Just as Francis Drake and I guess quite a lot of other guys.)“Whoo-hoo-hoo, look who knows so much. It just so happens that your friend here is only MOSTLY dead. There's a big difference between mostly dead and all dead. Mostly dead is slightly alive. With all dead, well, with all dead there's usually only one thing you can do.”
"...go through his pockets and look for loose change."
My name is Inigo Montoya. You killed my father, prepare to die!
That doesn't explain why he looked exactly the same in each instance of the Matrix. It could at best account for why his residual self image inside the Matrix would look similar from one revolution to the next, but his physical body would have to have the exact same set of genes, in exactly the right order to make him look the same each time around.Def
Quote from: Grant Lamontagne on April 09, 2012, 08:32:31 PMThat doesn't explain why he looked exactly the same in each instance of the Matrix. It could at best account for why his residual self image inside the Matrix would look similar from one revolution to the next, but his physical body would have to have the exact same set of genes, in exactly the right order to make him look the same each time around.DefHe didn't look the same If that was the case the Morpheus would have known him by sight. Remember Morpheus said "the one" woke up the first of us. It's very complicated but there's a program that controls that too.
