I think dedicated drivers (like a large flathead) on a tool with removable bits would be something I could do without. I agree with redundancy, but I would just get another bit driver.
I've considered the large flat-head as a specific tool as on the Leatherman Wave, and it occurs to me that it has more than the specific purpose of turning flatheads.
Quote from: Lynn LeFey on April 30, 2012, 06:15:50 PMI've considered the large flat-head as a specific tool as on the Leatherman Wave, and it occurs to me that it has more than the specific purpose of turning flatheads. That's the thing: every tool on a multi has multiple uses, if you apply a little imagination! Yeah, few of us open cans often enough to justify a dedicated can opener, but I use mine fairly often: the tip as an (admittedly lame) awl, the edge as a scraper, and of course the implement includes a wire stripper. Some folks have mentioned using the corkscrew to untie knots. I scrape and pry with the flat drivers all the time. Etc. etc. etc....
Regarding the knife blade issue, it depends on the tool, and whether you're carrying a separate knife. Most multi knife blades are awful, with thick edges, soft edges, awkward geometry, and of course a non-ideal handle; and unless one-hand opening, more trouble to access than they're worth most of the time. But one thing I like about the Charge/Wave is that the blades are both good enough quality and easy enough to access that I can do without a separate knife. So they do have a place, at least for some folks.
If I had a need to do more precise slicing or if I used a blade more then I would probably want a better blade with a better handle, but for me, the MT blade is a very good tool.
I'm probably in minority with my opinion but I would do just fine without scissors - even if I wouldn't have that Micra in my keychain. Also bottle opener is not important although I use that quite often - especially after I cut my finger when opening a bottle with serrated edge of folding knife. After all most important parts for me are pliers, blade and strong slot driver (...is that a correct term?) - pretty much can be done just with these tools and long history of watching MacGyver.
And why on Earth would you open a bottle with a serrated edge?
I keep wondering... of those people who say that you can use the corkscrew to undo knots... couldn't you use an Awl for the same purpose, and it'd be more useful overall? And for the SAK folks, yes, a corkscrew does give you a place to hold a mini screwdriver, but they could use that space for some other tool that could do mini screwdriver duty and something else. Maybe like a cybertool bit holder with a flip-bit or something.
So, looking over the responses, and crossing off the items not wanted, I've drawn a prototype of the MT that would satisfy most:(Image removed from quote.)
If only it had a philips screwdriver instead of a flat one....
