Following a minor washbasin drain plug lift (operation, reduction in ability of) alert in the bathroom, the picture below shows the Supertool 300 VX just after performing powerful, determined and decisive action on a stubborn drain plug lift control rod connector screw . Not in the picture, the subsequent powerful twisting action on the washbasin drain clamping sleeve using the plier heads inside some available and handy orifice on said sleeve, following the discovery that said sleeve had in fact been loose enough to impair the sealing function of the drain gasket, resulting in minor flooding.The Supertool was carried on the subsequent afternoon stroll by way of commendation and gratitude for services rendered..(Image removed from quote.)
So here I am on the road again Used Wave and it’s pliers just now to connect my MacBook Pro to the TV set in a hotel room. smurfs made it a tough mission to accomplish, but everything is possible with a Wave (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)Being done with that I can finally just sit down, relax, have a cup of herbal tea and watch “The Story Of Dick Proenneke”
Quote from: alexanderre on December 11, 2017, 07:32:43 PMSo here I am on the road again Used Wave and it’s pliers just now to connect my MacBook Pro to the TV set in a hotel room. smurfs made it a tough mission to accomplish, but everything is possible with a Wave (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)Being done with that I can finally just sit down, relax, have a cup of herbal tea and watch “The Story Of Dick Proenneke” OMG I hate when I see they've put the TV (with cable entry behind) so close to the wall. When a hotel, or any place whatsoever, has that kind of smurfed TV mounting they immediately lose a star on my list.
Nice work
Used my ST300, bit adapter and bits yesterday to take apart a few Stihl cut off saw pull started rope assemblies The star bit on the bit adapter was just the right size to take the spring out on a couple of them and now we have 3 extra rope pulls that can be mounted in the case of a rope break
Very nice work!
So you have no tone controls now (apart from varying the volume of the differing tone of the pickups)?
Quote from: Poncho65 on December 23, 2017, 04:45:09 AMUsed my ST300, bit adapter and bits yesterday to take apart a few Stihl cut off saw pull started rope assemblies The star bit on the bit adapter was just the right size to take the spring out on a couple of them and now we have 3 extra rope pulls that can be mounted in the case of a rope break Thos chainsaws are Stihl the best.See what I did there? (Image removed from quote.)
