What did you use your Leatherman for today?
trouthunter · 4939 · 319299
us Offline Philabuster
Re: What did you use your Leatherman for today?
Reply #3900 on: December 05, 2019, 07:46:19 PM
One of the common uses I have for my Leatherman ST200 is cutting off the steel banding around raw materials--in this case, a chunk of 8" diameter steel bar.  What I do is snip each side of the 3/4" wide steel banding with the cutters and then grab the band with the pliers and break the weakened band free.  Works great.
* 20191205_113357_resized.jpg (Filesize: 208.85 KB)
* 20191205_113238_resized.jpg (Filesize: 252.22 KB)
* 20191205_113502_resized.jpg (Filesize: 278.17 KB)
Reply #3901 on: December 05, 2019, 07:52:52 PM
Excellent use  :like: :tu:
us Offline Rapidray
Reply #3902 on: December 05, 2019, 10:44:44 PM
Cool usage!  :cheers:
Reply #3903 on: December 06, 2019, 12:39:19 AM
 :iagree: :like:
us Offline BadMechanic
Reply #3904 on: December 09, 2019, 05:20:44 AM
Used my surge and rev to bend a metal roller assembly. Didnt fit good enough for the spring to fasten. Used the rev to make room for the surge plier head. Teamwork makes the dream work
cs Offline marko14
Reply #3905 on: December 09, 2019, 12:58:08 PM
Replacing batteries
Sent from my SM-G960F using Tapatalk
* 20191208_185500.jpg (Filesize: 65.27 KB)
* 20191208_185705.jpg (Filesize: 86.54 KB)
Reply #3906 on: December 09, 2019, 01:27:25 PM
Great uses everyone  :like: :tu:
us Offline Rapidray
Reply #3907 on: December 09, 2019, 03:26:54 PM
Replacing batteries (Image removed from quote.)
Nice OHT  :like: :cheers:
Reply #3908 on: December 09, 2019, 11:13:21 PM
I used my newly modified right handed opening serrated blade on my P4 to open up my mail containing two more ST200s.   :woohoo:
* 20191209_145657_resized.jpg (Filesize: 182.93 KB)
Reply #3909 on: December 09, 2019, 11:29:10 PM
Nice ones Pb :like: :tu:
Reply #3910 on: December 09, 2019, 11:55:15 PM
Squirt PS4 knife cut open 3 packages we got today. That little knife cuts cardboard like its butter!
us Offline Rapidray
Reply #3911 on: December 10, 2019, 01:48:05 AM
Got to love EBay!  :like: :cheers:
Reply #3912 on: December 10, 2019, 01:36:59 PM
Great use BM :like: :tu:
Reply #3913 on: December 10, 2019, 03:26:10 PM
 :tu: The ST200 is a great tool.  I always liked those slide locks.
Offline Saridis
Reply #3914 on: December 11, 2019, 08:32:26 AM
Charge plus tti file is actually very good in cutting mild metal
Sent from my POCOPHONE F1 using Tapatalk
Reply #3915 on: December 11, 2019, 12:02:46 PM
Cool pics and great use, Saridis :like:
Reply #3916 on: December 11, 2019, 12:26:25 PM
 :iagree: great use  :like: :tu:
Reply #3917 on: December 11, 2019, 03:58:05 PM
I needed to install some press fit bushings this morning.  I used my ST200's awl to break up some dry ice to freeze the bushings, and then used the pliers to remove it from the dry ice and also to hold the cold bushing in place while I pressed it in the bore.
* 20191211_074524_resized_1.jpg (Filesize: 265.89 KB)
Reply #3918 on: December 11, 2019, 04:04:14 PM
Great use  :like: :tu:
us Offline Rapidray
Reply #3919 on: December 11, 2019, 04:45:44 PM
(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
Nice job!  :tu:
us Offline Rapidray
Reply #3920 on: December 11, 2019, 04:47:15 PM
Nice use!  :like:
Reply #3921 on: December 11, 2019, 05:19:51 PM
 :iagree: :like: :like:
Reply #3922 on: December 11, 2019, 07:14:42 PM
last night, I gave my Surge a work out...well I got the workout but surge was holding up good.
A shaft for a chain curve was tangled up with plastic strapping...so I pull out the BO Surge. first used the serrated blade. Did pretty well. It was 2-3in thick of it so it was no picnic. Tried the saw. Also did decent. got tired of sawing away, so pulled out the pliers. I put all my weight into pulling the cutting up pieces (250+lbs) and the Surge held on tight!
Needless to say, I didnt get it all cleared out (limited access, barely enough for the pliers) but had a good time.  :rofl:
Reply #3923 on: December 11, 2019, 07:20:06 PM
Sounds like you had fun  :D
Reply #3924 on: December 14, 2019, 12:36:35 AM
My work week has started!
On the label printer stacker (horizontal) the chute going up and placing the label was stuttering a bit. Took sides off, one which has belts, pulleys and electrical parts in the way.
Used my Rev to take out about 15 screws. Phillips was perfectly length and head size.
cs Offline marko14
Reply #3925 on: December 14, 2019, 08:12:58 AM
Thank you
Reply #3926 on: December 14, 2019, 01:28:26 PM
Great use of the Rev BM  :like: :tu:
Offline Saridis
Reply #3927 on: December 15, 2019, 04:53:12 PM
Difficult task but the high quality bits did well
Reply #3928 on: December 15, 2019, 04:56:19 PM
Offline Saridis
Reply #3929 on: December 15, 2019, 05:10:58 PM
It never ends
Total Receipts: $122.41
PayPal Fees: $6.85
Net Balance: $115.56
Below Goal: $184.44
39%
