What did you use your Leatherman for today?
trouthunter · 5150 · 395705
Re: What did you use your Leatherman for today?
Reply #4980 on: September 23, 2024, 11:00:31 AM
:like: and I'm curious as to how well the ferro rod works. I have a small one from Wazoo Survival gear, and I had a tough time getting it to spark. It's bigger than the one that comes with the Signal...
It actually works pretty well.  It isn’t going to throw huge flames, but it still works well.
Reply #4981 on: September 24, 2024, 12:37:32 AM
00 Offline Bigshep
Reply #4982 on: September 24, 2024, 03:18:26 PM
Used it to cut Apples
Sent from my SM-S908U using Tapatalk
vn Offline friendliestdoggo
Reply #4983 on: September 24, 2024, 08:28:58 PM
 :like: that's a lot of apples  :drool: looking good
Offline kaevin
Reply #4984 on: September 25, 2024, 03:36:52 AM
Moon cake instead of apples
00 Offline Bigshep
Reply #4985 on: September 25, 2024, 03:43:52 AM
 :like: :like:
Offline kaevin
Reply #4986 on: September 27, 2024, 11:35:52 AM
Moving to another apartment soon, with things need to be cleaned and fixed.
Zip tie cutting with surge, filing some metal to fit a door lock with the surge file (the file is surprisingly good)
And screwing in this screw, with a panel in the way of a screwdriver is used, this Leatherman carabiner I though is only for fun, is actually very useful this time
Reply #4987 on: September 29, 2024, 02:43:52 AM
I sometimes miss being in apple country where fresh picking and apple cider are common
Today the signal driver helped change out the soft loop on my knife sheath for a Ultiticlip
Reply #4988 on: October 02, 2024, 02:25:39 AM
During the Helene aftermath around here, the Rebar really pulled its weight with storm cleanup.
Phillips--handed to a buddy while we pulled the generator that was bought after Sandy and promptly never used--but needed just shy of 15 years later to power the fridge and freezer. He replaced missing screws that powered the generator's electric start.
Pliers--a lot of stuff. He also borrowed them to adjust an old Sears/Hilary Field Gear camping stove we used in place of the electric range (we also did a lot of cooking on the grill). I have been doing fence work, and the cutters also have done a ton of stuff when I wasn't going back to my tool roll to grab the Cobolt cutters.
Serrated Blade--cut some miner belt (conveyor) for making a seal on the bottom of a screen door to air out the basement (which is cut short to clear a step going outside). Tough stuff to cut. Finally, I used a Dexter Russell net knife. Honestly, Tiger Sharp are the best serrations on the market, especially on thinner blades. It zipped through the stuff like hot butter.
PS: We were out of power between 5 AM Friday and 6:30 PM today. Lots of damage around me. We got lucky to only end up with some fence damage (which is where I'm spending all my weekend) and a dented garage roof edge from half a tree falling on it.
Reply #4989 on: October 02, 2024, 07:58:46 PM
Great uses y'all :like:
Reply #4990 on: October 03, 2024, 02:16:42 PM
:like: :multi:
Being called in by.son to use my knowledge of electrical wiring to install an outdoor driveway light on a new brick  (fancy) pedestal he built to replace the pole light that was there previously.
Apparently the  wiring  did not seem to be standardized with Blk/white/green.
So to be prepared I located my multi-meter for tomorrow s task only to find the battery was dead.
REBAR put work.
us Offline IMR4198
Reply #4991 on: October 03, 2024, 02:57:45 PM
   Leatherman went along while doing a little roadside maintenance.  Best wishes.  G
 :D  [ You are not allowed to view this attachment ]
us Offline IMR4198
Reply #4992 on: October 06, 2024, 07:40:04 PM
A Leatherman helped to repair a space heater.  Doing things with your hands doesn't get easier as you get older.  Especially if your eyes are not so great.  It looked like the three stooges at some stages of the work. Shemp couldn't take a photo, so I will leave a picture of my morning tea with a Leatherman.  Herbal tea at that.  I know there is a SAKs With Tea thread, but I couldn't find a LM With Tea.  Might not be one?  Best wishes.  G
Reply #4993 on: October 06, 2024, 11:07:12 PM
 :like: and I'm unaware of a Leatherman with tea thread. You're not a coffee drinker?
pr Offline Juan el Boricua
Reply #4994 on: October 06, 2024, 11:47:09 PM
Made a platform base to "fix" together both my box and floor fans, using the Signal for cutting, marking and drilling tasks.
us Offline IMR4198
Reply #4995 on: October 07, 2024, 03:37:15 AM
   You know, Dan?  Leatherman users might not be tea drinkers.  Herbal tea, anyway.  This was Numi Honey Bush.  Some sort of South African shrub, evidently.  It is actually pretty good.  I fix coffee.  Tea.  Mostly in the cooler months.  I actually like cocoa too, but I haven't had any in ages.  They drink sweet tea down here.  Cold with lots of sugar.  I like it, but I stay away from it except for rare occasions.
    I know our friend Barry likes tea, but he is a Gerber and SOG man I think?  He probably knows why there is no Leatherman and Tea Club.  Best wishes.  G
 :whistle:
00 Offline Bigshep
Reply #4996 on: October 07, 2024, 03:56:35 AM
Cut steel cable with mine today
Reply #4997 on: October 07, 2024, 11:27:45 AM
@IMR4198: I know Barry has at least one Leatherman laying around. He also gifted me my Pulse. :hatsoff: (I returned the favor by sending him a SwissChamp.)
@Bigshep: That's heavier than I've used the wire cutters for. Good to see they're up to the job! :tu:
Offline kaevin
Reply #4998 on: October 19, 2024, 04:11:14 PM
Surge, cut a wire. Assembled a bike rack. Scissors cut all sort of things. Blade for unpacking boxes.
us Offline TexasAKM
Reply #4999 on: October 19, 2024, 09:57:42 PM
Last Saturday while hiking Guadalupe Peak, I used the Micra scissors to trim some toenails.  It was well up to the task.
Reply #5000 on: October 20, 2024, 12:15:55 AM
@kaevin: that's an interesting bicycle rack/stand!
@TexasAKM: is the Micra accompanied by a Rebar?
us Offline IMR4198
Reply #5001 on: October 20, 2024, 07:17:23 PM
Wingman helped patch up a hole in a no-longer-waterproof boot.  Might work.  Didn't cost anything to try.  Best wishes.  G
 :whistle:  [ You are not allowed to view this attachment ]
Reply #5002 on: October 20, 2024, 09:44:02 PM
As expensive as new boots can be, you'll really come out ahead if the patch job holds. Now, where is that "fingers crossed" smiley?
us Offline IMR4198
Reply #5003 on: October 20, 2024, 10:42:51 PM
   I didn't know there was a fingers crossed smiley.  I'm not all that current on my smilological representations.  I got a boot full of water yesterday from crossing a little creek.  Got to follow the old mantra.  "Use it up, wear it out, make it do, or do without."  Within reason, of course.  That was latex caulk for repair work.  It seems to stick to the rubbery sole very well.  Best wishes.  G
Reply #5004 on: October 21, 2024, 12:14:52 AM
I know there's a fingers crossed smiley somewhere. It's where exactly that's puzzling me. Latex caulk may well do the job. And if it was left over from another job, you had nothing to lose by trying!
ua Offline in_sympathy
Reply #5005 on: October 21, 2024, 11:59:18 AM
Oh man, it's been a while, but recently I pulled my Wave out of the drawer and realised that I really missed this tool  :multi:.
So I went straight to using it quite extensively 😀.
A few weeks ago I stumbled upon a tremolo guitar effect pedal from Seymour Duncan I wanted to buy like 20 years ago but somehow didn't. The price was good so I pulled the trigger. Put it into my pedalboard and realised that now I have two tap tempo pedals and have to tap both to set the proper tempo for each song. That's suboptimal to say the least, so I drilled a hole in this new pedal and soldered a wire to the jack output so now the tap tempo switch on my new tremolo also sets the tempo for the delay effect or any other effects I may daisy chain in the future. Turned out really well. Wave was used for wire stripping both with the new Plus pliers I have bought and installed recently as well as a dedicated tool. Stripping with pliers works much better than on a Spirit X - one thing Wave does indeed do better 😃.
Pics are below:
Reply #5006 on: October 21, 2024, 12:06:53 PM
But of course that was just the beginning :)
Also I finally installed lights at the balcony - there was some weird setup with electrics in place so it took some experimenting in order to make it work, but all done ✅. Main blade on a Wave was used for stripping the stupidly fragile aluminium wires and bit extender for attaching the lamp to those wires.
And while at it laundry hanging mechanism failed again:
So I drilled holes in the poles and fastened all of them with a zip tie - this way surely it'll last quite a few more years. Wave pliers were used for tightening and trimming the excess of the zip ties.
Reply #5007 on: October 21, 2024, 12:11:19 PM
Overall after having not used a Wave for a while at some point yesterday a thought came to my mind. I have decades of experience using different computers and operating systems and different approaches by different companies. That's why at some point yesterday I realised that Swiss Tool, Spirit and Victorinox overall is like a Mac or other Apple products.
While Wave and other LMs are definitely Linux to me.
No good or bad there - love and use both tools and platforms - each has its benefits. But that's 101% how I feel about it :) What do you think?
us Offline IMR4198
Reply #5008 on: October 21, 2024, 12:16:17 PM
Good to see you back.  What multi-tool is like Microsoft Windows?  Best wishes.  Gary
 :hatsoff:
Reply #5009 on: October 21, 2024, 12:25:53 PM
 :hatsoff:
Thanks a lot, good to be back :) No idea as for Windows - don't use it much :).
But as for LMs - I had to install an S30V blade, Plus pliers that I had to heat and loosen for a while, will install an awl later and only then Wave will become close to what I want it to be. Similar to Linux. Anything is possible but it takes time, effort, knowledge and persistence :)
On Vic multitools for me (!) it's much closer to perfection as is. Spirit not so much but on a Swiss Tool it really is. But you can't really change much if you want to - really reminds me about Apple platforms - only in some ways but still.
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $33.86
PayPal Fees: $2.12
Net Balance: $31.74
Below Goal: $268.26
 11%
January Donations
