What did you use your Leatherman for today?
trouthunter · 5189 · 492930
ua Offline in_sympathy
Re: What did you use your Leatherman for today?
Reply #5010 on: October 21, 2024, 02:22:53 PM
Good to see you back.  What multi-tool is like Microsoft Windows?  Best wishes.  Gary
 :hatsoff:
Having thought for a moment I guess Gerber is rather close to being Windows here 😃
us Offline ThisAlarm7
Reply #5011 on: October 21, 2024, 02:43:50 PM
 :hatsoff:
Well, since I despise Windows I'd have to say the equivalent would be one of those cheap crappy knock offs that will break right away.  :D
Reply #5012 on: October 21, 2024, 03:08:24 PM
Well I definitely don't hate Windows - there are apps that only exist on Windows that I use - for example an app for a thermal camera and a lab power supply - and those won't sadly work under virtual machines on a Mac or Linux. Not to mention games... So definitely no hate here - none of those platforms is bad - otherwise they won't even exist or would cease to exist IMO. So no good, bad, right or wrong answers here :)
It's just a subjective feeling, you know.
Reply #5013 on: October 21, 2024, 05:04:56 PM
Well you guys can tell I missed my Wave 🤣.
Our reverse osmosis tap started leaking a little recently. It's a rather old tap that has a rather old design. So I wanted to replace it with a more modern version, but sadly it was out of stock in the local stores. But today I stumbled upon one right next to where we live, so bought and installed it right away. Wave pliers did a surprisingly great job at cutting a plastic fitting  :multi:
Reply #5014 on: October 22, 2024, 01:03:21 AM
Good stuff! :like:
Reply #5015 on: October 22, 2024, 05:21:10 PM
Thanks, Farmer X  :cheers:
As for the good stuff - today I guess I finally made me a Wave I really like. First I put onto this Linux system an S30V blade years ago. And had a 154CM before that. Then a few days ago I put a Wave Plus plier head. Too bad I missed a chance to have one with 154CM cutters and not those doubtful 420HC, but what can you do.
And today I finally managed to get a Rebar awl in there. Took quite a bit of time and effort filing plier support, scissors support, awl thumb stud and so on, but seems to be well worth it - now that's a Wave I always wanted :multi:
P.S.: one thing to add would be a LM ratchet of course, but that seems to be a surprisingly rare treasure for some unclear reason :)
« Last Edit: October 22, 2024, 06:07:52 PM by in_sympathy »
Reply #5016 on: October 23, 2024, 01:27:04 AM
us Offline TexasAKM
Reply #5017 on: October 23, 2024, 04:37:14 PM
@TexasAKM: is the Micra accompanied by a Rebar?
Howdy Farmer!
More like the Micra is accompanying the Rebar!  That Rebar is the tool I carry the most.  I do like the Micra, it is a fine tool.
00 Offline Grand_Banana
Reply #5018 on: October 23, 2024, 04:46:47 PM
A couple of days using the Kick to check resistance on a humidistat and replace a glide on a toy box.
vn Offline friendliestdoggo
Reply #5019 on: October 23, 2024, 07:43:41 PM
 :like: great uses you guys  :like:
Reply #5020 on: October 24, 2024, 01:13:21 AM
Nice to see the Kick getting some love and use! :tu:
Reply #5021 on: October 25, 2024, 10:33:43 PM
Decided to add some RAM to our old ASUS laptop that I use sometimes to play video of Windows games or to control my lab power supply and other electronics equipment.
It’s a really old one and it was crazy powerful back in a day. Also it’s the heaviest laptop I know.  But it only had 8Gb of RAM which was cool then but is not much these days. So while the proper RAM sticks are still available and are really cheap A I decided to make it even cooler, since it easily runs latest Windows and Linux versions and I already fixed any other issues it had, also having replaced two of its HDDs with SSD drives.
Used main blade to open the replacement RAM and then an eyeglass screwdriver to pop out old memory.
Celebrated the successful upgrade with some coconut juice - now I can do it with my newly installed awl 🙌🏻
Reply #5022 on: October 26, 2024, 02:16:15 AM
You're pretty well speaking Greek to this wrench-turner, but nicely done! :tu:
Reply #5023 on: October 26, 2024, 03:19:01 PM
Oh, no worries there - I just doubled the amount for memory in that old laptop :) sorry for making it sound complicated 😬
Offline kaevin
Reply #5024 on: October 26, 2024, 04:14:16 PM
Removing shelves from wall. Extender is a great help as the handles would get in the way.
Offline kaevin
Reply #5025 on: October 26, 2024, 04:26:03 PM
Old laptop and linux are nice.
Reply #5026 on: October 27, 2024, 01:01:05 AM
 :iagree: I had a laptop that was running Linux by the time I replaced it...but that story is best suited for another thread.
Reply #5027 on: October 27, 2024, 12:51:47 PM
Nicely done 👍🏻. I wish ratchet would get back in stock soon - those jobs would be much easier 😃
Reply #5028 on: October 28, 2024, 12:30:04 PM
Well my kitchen scissors don't cut so well anymore so I used the Wave+ diamond file to sharpen it. Now the scissors work fine again  :D
Reply #5029 on: October 28, 2024, 11:20:39 PM
Well done! :tu:
Offline kaevin
Reply #5030 on: November 08, 2024, 06:56:38 PM
Tighten up a coffee table leg with surge. Couldn't do it with pst cos its a hex.
Reply #5031 on: November 09, 2024, 10:24:27 AM
I have a similar issue when I need to manipulate a Torx screw at work. My ST300 doesn't yet have an add-on bit driver, so I have to use dedicated tools. That's what we do: make things work! :tu:
Offline kaevin
Reply #5032 on: December 02, 2024, 04:41:33 AM
Quickly remove some hooks from the partition with surge ratchet driver and a funny adaptor.
Reply #5033 on: December 03, 2024, 12:59:39 AM
Offline kaevin
Reply #5034 on: December 03, 2024, 01:37:52 AM
I had put on a lot of screws and hooks around it to hang toolbags and clothes. Not it's time to revert it.  :facepalm:
This combo really gets the job done fast and easy.
Offline kaevin
Reply #5035 on: December 07, 2024, 09:48:49 AM
Removed 2 pins from 2 dolls for the kids with the pliers
Reply #5036 on: December 10, 2024, 05:57:00 PM
Used the PST blade to cut open a bag of wood pellets this morning.  I didn't get a picture  :facepalm:
Reply #5037 on: December 11, 2024, 01:06:24 AM
For a pellets stove?
us Offline Rickochet
Reply #5038 on: December 11, 2024, 03:05:21 AM
I used my Leatherman Free P2 to cut open some boxes and cut & strip some 14 gauge wire as I upgraded a friend's garage antiquated lighting to  LED's.  It's the tool that can do everything.... almost!     :woohoo:
Rick
Doing something right the first time is always faster than having to do it again.  Plus you don't have to explain why!
Offline kaevin
Reply #5039 on: December 11, 2024, 03:35:17 AM
No action shot:
Tightened a screw in the Ikea Norden table with the Leatherman inline ratchet driver and a Vessel ball grip (220W-62). The other side with limited space I used hex bit clamped by Knipex Cobra 125 (not enough space even with a regular hex bit ratchet).
