whats your daily kit
dingosrun · 229 · 23578
us Offline ducktapehero
Re: whats your daily kit
Reply #150 on: February 25, 2008, 12:22:40 AM
Quote
The black and white item is a thumb drive.  There's also a Rambler and a P-38...
I recognize the P-38. I love those things. They're extremely versatile multi-tools in their own rights. I have a P-51 on my keychain, along with a 12"x1" piece of ducktape wrapped around it. With my fumbly arthritic fingers I need the bigger one.
Here's a couple links about the P-38 for those who may not know.
http://www.georgia-outfitters.com/page52.shtml
http://www.p-38.net/
Reply #151 on: February 25, 2008, 12:37:15 AM
I got a P-38 from Calvin and it does look like a pretty handy piece of kit.  :)
us Offline NutSAK
Reply #152 on: February 25, 2008, 12:41:50 AM
That's a great idea DTH.  I have troubles with mine unfolding in my pocket and stabbing me at times.  I think I'll wrap a few inches of gaffer's tape around it.
- Terry
Reply #153 on: February 26, 2008, 01:39:42 AM
Here's what I had on my today...
I use the lanyard and S-biners to attach my keys.
Reply #154 on: February 26, 2008, 01:41:21 AM
Is that one of those Grim lok doodads there?
What are your thoughts on it?  They intrigue me and I'm not certain why....
Reply #155 on: February 26, 2008, 01:44:41 AM
It is indeed. They are pretty handy to have.  I use it quite a lot at work as I often have to carry around 2 sets of keys so it comes in handy then.  I also use it to attach my Cold Steel CBK's sheath to my belt loop when I am carrying that around.
They do feel pretty solid and well made.
Reply #156 on: February 26, 2008, 01:47:43 AM
I guess I'll have to look closer them now then!
us Offline NutSAK
Reply #157 on: February 26, 2008, 02:15:38 AM
Which doodad is a Grim lok?  Is that the black thing?  I googled it and got nothing.
- Terry
Reply #158 on: February 26, 2008, 02:17:38 AM
The D ring thing in the top left corner of the pic.
There have been a few pictures of them posted, but no real good closeups.  They seem to decorate the backgrounds mostly!
gb Offline Roadie
  • Hello...is this thing on?
Reply #159 on: February 26, 2008, 10:00:31 AM
Someone ask for close up shots? Second shot the grimloc is open fully. To open them you push the plunger down and it releases the end of the gate.
us Offline NutSAK
Reply #160 on: February 26, 2008, 01:46:43 PM
That looks pretty useful.  It looks like you can attach it to a strap also, using the slot on the handle, right?
Are these made for the military?
- Terry
Reply #161 on: February 26, 2008, 01:49:47 PM
Yeah they have been made to fit 1" webbing.  Here's a link http://www.maxpedition.com/store/pc/viewPrd.asp?idcategory=0&idproduct=15
us Offline NutSAK
Reply #162 on: February 26, 2008, 01:54:27 PM
Thanks!
- Terry
Reply #163 on: February 26, 2008, 02:06:42 PM
Maxpedition makes them?  Hmm, I'll have to talk to Marc at www.EDCDepot.com since he deals in Maxpedition stuff....
Reply #164 on: March 03, 2008, 12:47:14 AM
I've started to carry one of these as well http://www.countycomm.com/1x4driver.htm.  Really handy little tool.  Real cheap as well!
Offline Anthony
  • Improvise.
Reply #165 on: March 03, 2008, 01:04:37 AM
I have one in my bag.  It's the best screwdriver of it's kind I've come across...and only $3!!!
Reply #166 on: March 03, 2008, 01:09:09 AM
The bits are really good quality aren't they.  :)  I used it the other day to dismantle my laptop as I have got a problem with my LCD.  I only used that screwdriver and it worked really well.  (disn't manage to fix the problem though  :()
Countycomm have some really good items at really cheap prices.  I have one of those SO-LED's as well and for the cost it is AMAZINGLY bright.  I can't understand how their stuff is so cheap.  :think:
Offline Anthony
  • Improvise.
Reply #167 on: March 03, 2008, 01:45:25 AM
Thier shipping isn't bad either...UPS at their cost it seems...no "handling" fee really.
The bits on that screwdriver are really well cast and the steel seems like quality.  The plastic handle is indestructable it seems to.  I've owned a few chinese made tools with a similar design and they were all very poor...but cost almost twice as much :P
Offline Leatherman123
Reply #168 on: March 03, 2008, 01:49:45 AM
The peanut lighter is also high quality!
B
Offline cryptrick
Reply #169 on: March 03, 2008, 08:05:49 PM
Whats up with your laptop ben?
Reply #170 on: March 03, 2008, 08:48:55 PM
I've got a dry joint somewhere that causes the LCD to flicker and go all liney.  It looks similar to a frame IC failing on a CRT TV.  Can't seem to find it though.  >:(
Offline cryptrick
Reply #171 on: March 03, 2008, 09:02:44 PM
Yeah it sounds like it could well be a dry joint or a fault in the ribbon cable which connects to your LCD. Doesn't sound like the actual LCD is at fault but technically it could be. Also doesn't sound like the inverter as they give the required voltage to the backlight. Hope it is just a dry joint, a new LCD will be quite costly.
Reply #172 on: March 03, 2008, 09:05:47 PM
So do I.  :-\
It is definitely connection related as I can tap it to cure it, but I just can't find the damn thing. >:(  When I did TV's, you could spot a dry joint a mile off as it was either black or sparked.
us Offline NutSAK
Reply #173 on: March 03, 2008, 09:08:28 PM
Yeah, it's much easier when you're working with high voltage to spot cold joints.
- Terry
Reply #174 on: March 03, 2008, 09:11:42 PM
Didn't have many ribbon's go wrong either.
I liked working on higher voltage stuff.  When I was learning, I did get the odd bite off of the EHT cap though  :D.  That hurt!
Offline cryptrick
Reply #175 on: March 03, 2008, 09:13:43 PM
Hmmm, I know the last one I looked at at work was a fault in the ribbon cable to the screen. You could press it firmly and it would be perfect, let go and the screen all pink and wavey. I don't actually do a load of laptop Board Level repairs so my advice now would be look for a dry joint again and reseat that ribbon cable just to make sure.
Reply #176 on: March 03, 2008, 09:17:10 PM
I tested the ribbons and they seemed fine :-\.  The problem is it is so intermittant.  I was tapping and wiggling all the ribbons and connections I could see and I couldn't get the fault to happen.  Damn electronics.  :twak:
Offline cryptrick
Reply #177 on: March 03, 2008, 09:18:27 PM
Intermittent problems are the worst aren't they :-\
Reply #178 on: March 03, 2008, 09:20:39 PM
They are.
I had an old Hitachi TV a while back that had a line fault that was a dry joint as well.  I spent months trying to find it and I never cured it.  In the end I just learnt to live with it and gave it the odd whack every now and then  :D
Offline cryptrick
Reply #179 on: March 03, 2008, 09:23:54 PM
They are.
Lol, it is surprising how many monitors can be cured by a good whack! I used to love whacking my old monitor years ago... until I broke it for good in the end. :D
