Tip: simple cover for the exposed gears on older SOG PowerLocks
us Offline parnass
  • 4x4 since '74
Older SOG PowerLocks and other SOG tools have exposed gear teeth which can make using the multitool painful when applying downward force.
A flexible plastic pipe end cap can be placed temporarily over the end of the multitool to shield your palm from the sharp gear teeth.  A 1 inch (inner diameter) cap fits well over the end of the PowerLock.  A smaller diameter cap can be used to cover the teeth on other SOG multitools.
The pipe cap I used is very flexible and feels similar to the synthetic rubber material named Plasti Dip.  Sorry, I don't know of a supplier for these caps.  I found this one in a parking lot behind a home center store.
« Last Edit: July 02, 2012, 02:17:24 AM by parnass »
Retired engineer, author.
Cool- I never thought of that!
Thanks for the tip!
us Offline neillcurrie
  • Wanted: SpydeWrench
Re: Tip: simple cover for the exposed gears on older SOG PowerLocks
Reply #2 on: October 16, 2014, 09:12:41 PM
Necro-thread-resuccitation:
I use essentially the same idea, but I shrunk a length of shrink tubing over the gears. This has a few advantages, apart from the obvious protection. Depending on how tight you shrink it, it'll pop off and on easily, and it's quite a bit thinner than the end cap so will live on the end of the SOG when it's in a sheath, so it's harder to lose too.
00 Offline jaiyenjang
  • New User
Reply #3 on: November 24, 2014, 12:11:37 PM
I commend you on the subject just to let others know.
