... The jaws open wider than any tool I've had, BUT, if you're trying to grip something really wide, you need to use two hands (one on each handle). ...
Quote from: Corrugated on February 20, 2008, 12:15:42 AM ... The jaws open wider than any tool I've had, BUT, if you're trying to grip something really wide, you need to use two hands (one on each handle). ...Or position the PowerLock's handles as shown below. The jaws open wider and the gearing permits you to apply force.(Image removed from quote.)
Ahhh... Good idea, Benner. I may try that. I have tons of those bits lying around. I think I'll check and see if I have a bit holder handy. I have a sheath with a built-in bit holder in which I used to carry my Gerber Legend 800. I just couldn't get on with the Gerber and retired it for my Wave. I'll see if its bit holder works with that.My thanks to you all, Bill.
Also the socket needs to hold the bit somehow...something with either one of those retention wires (don't know the correct term), or a magnet.I still haven't found anything that would work.
