Hm, what kind of a jig did you have in mind? To do what? Just cut the scales shape, profile them, drill rivet holes (and yes, no problem there) or all of the above? What tools did you intend to use? I'll probably be making plus scales out of oak this week so I can beta test it for you.
The only jig making I did was for liner making, but it worked perfect. I still use the same method to cut liner from brass and 6061 aluminum, although Ive refined my jig somewhat, the principle is the same still.http://forum.multitool.org/index.php/topic,35639.0.html
Quote from: Syph007 on July 12, 2012, 02:29:27 AMThe only jig making I did was for liner making, but it worked perfect. I still use the same method to cut liner from brass and 6061 aluminum, although Ive refined my jig somewhat, the principle is the same still.http://forum.multitool.org/index.php/topic,35639.0.htmlThat's more or less the route I intend to take, Syph' Lots and lots of acrylic templates.That router base for the dremel, has shocking reviews on amazon.uk.The general consensus is that it wobbles like crazy - which, if the case makes it totally pointless.What are your views on it? Because if it could be used "Accurately" I'll definitely get one.Would be a damn sight easier than using any of the 1/2" beasts I currently use. ToshBut without a shadow of doubt, CNC Routering is definately the way to go with this idea.Then the only limitation is your imagination - (hey, that sounds like a good song)
Have you thought of using a laminate trimmer? they are easier to control than a full sized router
If you do go with the trimmer Makita make a plunge base for theirs
