Rivets became hidden on 91 mm Vics in 1961 so the smooth-edge orange peeler probably dates to before then; the head of the tweezers (on 91s at least) went from metal to plastic in 1978 so the large-tooth peeler is likely after 1977; with the small-tooth peeler in between. These dates from the SAK OM, by way of Victorinox public relations dept.Tang stamps (ie, Victoria only before 1975), shield metal (nickle-silver before 1980, then stainless steel) and scissor-springs (single, double, blue, stainless - what dates for these?) might narrow things down. The grind/shape of the peelers, back and front, has had some variation over the years also...
Quote from: J Mackrel Jones on September 04, 2013, 11:08:59 PMRivets became hidden on 91 mm Vics in 1961 so the smooth-edge orange peeler probably dates to before then; the head of the tweezers (on 91s at least) went from metal to plastic in 1978 so the large-tooth peeler is likely after 1977; with the small-tooth peeler in between. These dates from the SAK OM, by way of Victorinox public relations dept.Tang stamps (ie, Victoria only before 1975), shield metal (nickle-silver before 1980, then stainless steel) and scissor-springs (single, double, blue, stainless - what dates for these?) might narrow things down. The grind/shape of the peelers, back and front, has had some variation over the years also...Thank you, I ordered THE book a few days ago, going it will help answer this type of thing in the futureSent from my SPH-L720 using Tapatalk 2
Quote from: detron on September 04, 2013, 11:23:07 PMQuote from: J Mackrel Jones on September 04, 2013, 11:08:59 PMRivets became hidden on 91 mm Vics in 1961 so the smooth-edge orange peeler probably dates to before then; the head of the tweezers (on 91s at least) went from metal to plastic in 1978 so the large-tooth peeler is likely after 1977; with the small-tooth peeler in between. These dates from the SAK OM, by way of Victorinox public relations dept.Tang stamps (ie, Victoria only before 1975), shield metal (nickle-silver before 1980, then stainless steel) and scissor-springs (single, double, blue, stainless - what dates for these?) might narrow things down. The grind/shape of the peelers, back and front, has had some variation over the years also...Thank you, I ordered THE book a few days ago, going it will help answer this type of thing in the futureSent from my SPH-L720 using Tapatalk 2Which book is that? Where can I order one?
I do not think soSent from my SPH-L720 using Tapatalk 2
