Kershaw T-Tool
damota · 16 · 1953
Offline damota
Kershaw T-Tool
on: February 26, 2008, 01:49:16 AM
The Kershaw T-Tool looks kinda interesting for interfering with your knives and multi-tools (moding and maintenance) just seen one (and ordered it). Not a multi-tool but a looks useful. Let you know what its like if anyone is interested?
Dave
* 2657.jpg (Filesize: 57.86 KB)
ca Online Grant Lamontagne
Re: Kershaw T-Tool
Reply #1 on: February 26, 2008, 01:50:42 AM
I am- I'm not familiar with that one.  Do you have any better pics of it?
Re: Kershaw T-Tool
Reply #2 on: February 26, 2008, 01:52:26 AM
I saw that on Heinnies and it looked good for the price.  :)
Offline Anthony
  • Improvise.
Re: Kershaw T-Tool
Reply #3 on: February 26, 2008, 02:12:17 AM
Countycomm.com recently got them for sale.  Lots of pics to!
http://www.countycomm.com/TORX.htm
Re: Kershaw T-Tool
Reply #4 on: February 26, 2008, 08:52:00 AM
That looks like a handy little tool, especially for the price :)
scotland Offline Sea Monster
Re: Kershaw T-Tool
Reply #5 on: February 26, 2008, 09:46:32 AM
I'm not sure why they supply shortened bits, but anyway, it's just a bit driver with some Torx drivers supplied.
What's the excitement?
us Offline Spoonrobot
Re: Kershaw T-Tool
Reply #6 on: February 26, 2008, 11:08:15 AM
The bits are in the Std. Sizes Professionals Use!®
i.e. they are around the right size to adjust pocket clips, pivots and so forth on most folding knives. Kind of like Benchmade's BlueBox but not nearly as poorly made.
Offline flapjackboy
Re: Kershaw T-Tool
Reply #7 on: February 26, 2008, 11:13:09 AM
I think what Nomad was referring to was that the hex shank on those bits doesn't look like it's the right length. Probably so that they can fit them all into the shaft of the driver. (Or, as the cynic in me was suggesting, so that they can flog you extra bits, like Leatherman do.)
Re: Kershaw T-Tool
Reply #8 on: February 26, 2008, 11:26:00 AM
I was responding to this part.
Re: Kershaw T-Tool
Reply #9 on: February 26, 2008, 07:43:43 PM
Quote
While the bits are shorter, I suspect the remaining dimensions are standard, so you could bung in any ol' bits you like.
Quote
Is it a bit of a leap of faith to say a set of Torx will see you home?
Seems many have Socket bolts, and the Rivet ones are a whole other issue.
us Offline hawkchucker
  • I miss Benner
Re: Kershaw T-Tool
Reply #10 on: February 26, 2008, 09:44:23 PM
I kind of think it would be a cool little gismo to keep in the maint, box where I keep all my tools.
S
us Offline Mike
  • Shop smart, shop S-Mart.
Re: Kershaw T-Tool
Reply #11 on: February 26, 2008, 10:21:35 PM
Think I'd rather go for one of these from SaberTooth tools:
Pocket T-Driver
Ratchet T-Driver
Mike
Offline damota
Re: Kershaw T-Tool
Reply #12 on: February 27, 2008, 02:33:34 PM
Quote
The bits are 9mm along the hex part and the blade portion is standard size. Anyone needing a special bit (such as the LM 5 star torx (if he has got hold of one)) would have to remove 5mm from a standard bit, could be cut with a standard hacksaw. The blade part of the bit fits in a hole at either end again reducing the length needed to store the 3 bits, so at least one bit needs to be of a similar diameter to the original bits or it won't fit if stored at the end. The tool has a length of 92mm and seem to be made of heavily lacquered aluminum.
Quote
[/quote]
The T6 is hard to get on its own and is used by most of the well known Knife companies (as well as phone manufacturers) T8 also is used throughout the industry but is more likely to be found in a standard set. The X point is a size 0 (used by many for fitting clips) although I have none that use X point I do have a single knife that uses a flat and can soon alter an appropriate bit to fit.
First job that needs doing to it is to get rid of the triangular peice of the key chain and relace it with a small split ring.
I agree a similar tool with Alan heads would be desirable but they do seem to have fallen from grace recently as for riveted tools a power drill is a bit big for anyones pocket on a just in case basis they just need binning then maybe the manufacturer will use screws of some type to allow home maintenance and price them right instead of using cheap fixings.
Dave
us Offline Smitty44
Re: Kershaw T-Tool
Reply #13 on: February 28, 2008, 06:10:46 AM
Thanks for the update damota,the T-tool must be pretty popular,a couple places that I inquired about them were sold out already,they must be catching on,looking to get one myself,and probably redoing some bits also.
Offline damota
Re: Kershaw T-Tool
Reply #14 on: February 28, 2008, 02:32:34 PM
As an afterthought on my comment on a one with Alan key bits I wonedre if as there are both metric and imperial sized Alan keys if that was the reason they are not being used as much as they used to be. They wouuld have to produce 2 sets. I know they are sods to sort out if you get the L shaped keys mixed up.
Dave
Added
You do not need to cut any added bit if you store the first point down the added bit then another bit that came with it point up as both the original bits will fit in the added holes I mentioned at each end leaving enough space for the unaltered bit.
« Last Edit: February 28, 2008, 05:55:45 PM by damota »
Re: Kershaw T-Tool
Reply #15 on: February 28, 2008, 07:39:32 PM
Quote
I have a few 1/4" bolts with socket (allen) heads.
They have all been expertly rounded by metric keys.
Total Receipts: $36.34
PayPal Fees: $1.66
Net Balance: $34.68
Below Goal: $265.32
 12%
