I've got a few Farmers and none of mine wiggle You could always send it in to Vic to have it repaired mate if its niggling you too much
Quote from: Mike, Lord of the Spammers! on September 06, 2012, 08:30:43 AMI've got a few Farmers and none of mine wiggle You could always send it in to Vic to have it repaired mate if its niggling you too much If it's not the norm that they wiggle then I will happily just buy a second one, this one can just be my every day Farmer and I will use the other one as my outdoors Farmer. I just didn't want to use it as my outdoors one with the wiggle because I will be pulling it out of my pocket every time I need it by the lanyard, which would continue to stress the key ring attachment. It's not a huge deal to me, definitely not enough to bother sending it in. Looks like I'll have to put in an order for my second Farmer soon
Now that's a positive outlook on things. A+ good man.
Do you mean wiggle as in rotates on the pin a little, or wiggle side to side? If you mean rotates slightly on the pin, all of the new ones Ive bought are like that. Probably 60 or so in the last few months and they are all like that. Maybe they move about 1mm or so. I don't have any older ones to compare it to, but the fit up is for sure not tight on the new ones. When I put in the Titanium key ring spacers on customs I try to make sure they have no wiggle.
It is not a side to side, it is rotating on the pin. If it is a common problem, will it's range of movement continue to increase or is it already moving as much as it's ever going to?
