Questions about the slide lock, do you need 2 hands to lock the plier or can it be done with just one? If so, is it easy?
Top stuff Russ .Russ does the OHT's pliers rattle at all , Gerber's sliding pliers tend to rattle around a bit when not deployed .The OHT looked like a bit of a brick , how does it compare in hand too your Surge & Charge mate . The drivers & blades look a OK size how do they compare size wise to your other LMs (Charge & Wingman) Thanks mate , initially I was a bit cold on the OHT , it looks better than I was expecting
