i dont tend to take too much with me when cycling - ill regret it one day i know! i wont list my stuff right now but think i have learned is buy a track pump and make sure your tyres are the right psi before heading out sometimes saves you from unwanted and unnecessary flats roadie and slowly getting back into montain biking
why carry the Co2 if you have a pump? more to carry plus a pump always never runs out! (can understand Co2 in a race situation i guess)what clothing do you wear? now its getting colder im starting to look for jackets /long jerseys
Crunch and some bits. Those locking pliers are invaluable on the trail.S.
Yep stealth all in my backpack,although i usualy use my hydration pack for mtb'ing but sometimes its a squeeze ,my road bike is a much lighter set up but i prefer getting off road and away from the crappy car drivers around here
I don't bike often, but here 's the tool kit I've cobbled together:LM Style PS - I like the spring loaded pliers to remove thorns and prickly bits from my tires.4 inch Crescent wrenchStubby bit driver for the #2 Phillips bit. Also has a slotted driver, but don't think there are any slotted screws on the bike.5mm Allen key/hex wrench. These bolts are everywhere!Small patch kit, which does me no good since I need to pick up a frame mounted pump 2x lever wrenches, to remove tire and tube from the wheelI need a chain tool, tooOther bits and bobs:Spyderco H1 serrated rescue salt, in black. I don't know why I bring it, just do. Being a sheepsfoot blade, it would be great in an emergency.Orange Camaelbak MULE, with 3L reservoirChapstick
Same pump I use Heinz(Image removed from quote.)
Depends on the distance I'll be riding, but mainly:-4,5,6 mm Allen wrenches.-Co2 inflater.-Tube.-Patch kit.-Tire lever.-Chain breaker and extra links. (Usually just on longer rides.)-Water bottle and food (usually seeds/nuts).-Phone, credit card, ID, $20.I took my multi tool apart to mod it awhile ago, and haven't put it back together yet. When I get around to that, that'll replace my loose Allen wrenches and chain breaker.
well it was a wet and cold day, lots of mud and big puddles here is a pic of my stuff, not including tube under my saddle and altoids tin with batteries in my backpack i forgot to get out, although was pouring down if on my road bike i just have the saddle bag with tube,tire levers and my p4, stopped here and had a chat with sparky (Image removed from quote.)
